Old 11-05-2021, 10:08 PM   #1
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
Default Front wheel with more than 2 1/4" backspace
I am using a 26" front tire due to inner fender wheel clearance on my 1980 Camaro. The wheel is 15 x 3 1/2" with a 1 3/4" backspace. I see wheels with 2 1/4" backspace but I don't think that is enough. Does anyone know of a 15 x 3 1/2" wheel with more than 2 1/4" backspace? I hate the BMFH.
thanks, Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 11-06-2021, 01:29 PM   #2
SSDiv6
Default Re: Front wheel with more than 2 1/4" backspace
thanks, Ray
Contact Bogart Wheels and they can custom make any wheel you want.
However, make sure you will have enough clearance for the brake caliper.
Old 11-06-2021, 07:43 PM   #3
Jeff 2023
Also check out Holeshot wheels. I think they make 1 front wheel with up to 2 and 7/8 offset . Probably a 15x4 though
Jeff 2023 is offline   Reply With Quote
Old 11-08-2021, 08:40 AM   #4
dragracerray
SSDiv6 (I wish I knew your name) thanks for the tip. I will get in contact with them.
Jeff you are right Holshot makes a bigger backspace but the wheel is wider. I am trying to move the wheel towards the motor to get more clearance with the inner fender well. So a wider wheel with bigger backspace doesn' t help my problem.
thank you for the help. Ray
Ray Bassett
Old 11-08-2021, 02:46 PM   #5
SSDiv6
Talking Re: Front wheel with more than 2 1/4" backspace
My name is Joe and I am not the Brandon/Joe.
If you call Bogart, try to reach Ricky and explain the situation and let him know the type of front brakes you are using. He is a wealth of knowledge and information as regards to drag racing wheels.
Old 11-08-2021, 04:11 PM   #6
Mike Gray
Mike Gray's Avatar
Liked 711 Times in 205 Posts
Jegs has a Racestar wheel with a little over 2 1/2 back space
63-Series Pro Forged Wheel
Size: 15" x 3.5"
Bolt Circle: 5 x 4.75"
Back Spacing: 2.55"
Offset: +13.7 mm
Finish: Polished
Features:
