Old 08-18-2021, 08:15 AM   #1
Liked 11,032 Times in 2,267 Posts
Default Cleaning an aluminum head
What is the best way to remove carbon buildup. The wire brushes I used on the iron heads are too aggressive for the aluminum heads.
Thanks
Old 08-18-2021, 08:36 AM   #2
Ronnie Hamlin
Liked 29 Times in 8 Posts
Default Re: Cleaning an aluminum head
3M makes plastic Roloc discs for cleaning aluminum parts. I think they call them bristle discs and are available in different amount of aggressive according to the color. I tend to use the yellow ones
Ronnie Hamlin is offline   Reply With Quote
Old 08-18-2021, 10:05 AM   #3
SSDiv6
Oven cleaner, Super Clean, Brake cleaner, 100 grit 3M Pro-Pad Hand Sanding Sponge and lots of elbow grease.
Old 08-18-2021, 10:15 AM   #4
Greg West
Liked 52 Times in 22 Posts
We used Snap-On (Bluepoint) p/n AC16C wire brushes in our test labs. These brushes would not damage aluminum heads or blocks. The wire diameter is .006" so they are quite soft.
Greg West is offline   Reply With Quote
Old 08-18-2021, 11:06 AM   #5
FED 387
Liked 336 Times in 183 Posts
Larry--- you might look into using Berrymans Chem Dip-# 0996 carb cleaner--dont soak parts for more than 30-45 minutes at a time and "lightly" brush the carbon with a parts cleaning brush ---then take a shop towel and "dry and rub the carbon" it will come off just takes time depends on how bad it is may have to repeat the procedure multiple times--- Dick
Old 08-18-2021, 12:36 PM   #6
I got some Dremel tool wire brushes the steel wire ones last longer than the brass ones. And have some ss steel tooth brushes to use in the runners with brakeclean.
Thanks for all the good ideas.
Common sense in abundance is genius!
