Old 08-07-2021, 12:50 AM   #1
Bruce Fulper
Liked 54 Times in 33 Posts
Default Who's the local So. Cal. Jericho guru?
Seeking help on inspecting an early Jericho. Get it ready for racing.
Thanks
Bruce
909 844 ten eighty one
Bruce Fulper is offline   Reply With Quote
Old 08-08-2021, 08:17 PM   #2
Bruce Fulper
Default Re: Who's the local So. Cal. Jericho guru?
Doesn't anyone run a Jericho in Stock or S/S So. Cal.?
Old 08-09-2021, 07:25 AM   #3
Mike Jones
Liked 684 Times in 289 Posts
Bruce,
They are all switching to metric 200`s by Mark Yacavone. He posts on here and lives in AZ.
Old 08-09-2021, 02:55 PM   #4
SSDiv6
Because a lot of drag racers have switched to the G-Force transmission.
Old 08-09-2021, 03:24 PM   #5
Grey Ghost
Grey Ghost's Avatar
Liked 210 Times in 88 Posts
Does anyone in So Cal run a stick????
Phil Vos
Grey Ghost is offline   Reply With Quote
Old 08-09-2021, 06:47 PM   #6
Bruce Fulper
There are a few, and I will be one. Thanks for all of the direct positive responeses.
Old 08-09-2021, 07:21 PM   #7
Bruce, Don Keen probably knows a bit about that trans. I don't know if he does any side work.
Dennis Alvey knows them inside out, over here in Az. Again, I don't know if he would want to be involved..He stays pretty busy.
Looking forward to seeing this new piece. :-)
Old 08-10-2021, 05:21 AM   #8
james schaechter
Liked 1,443 Times in 302 Posts
The first thing you should do is look for the case number. It is stamped on most cases on the outside.
Call Jerico and find out what version it is. That will determine if it is a narrow gear or wide or what it is.
Take the covers off and count the teeth. Compare it to the gear ratio chart on Jerico’s web site
Look at general condition. Roll it over in each gear to feel for tight spots. Look at dog rings and sliders.
Beyond that it really needs disassembly to check it out.
If it is a narrow gear, it isn’t worth buying unless it has the ratios you need, is in good condition and in a low power light weight car.
You can’t get many parts for the narrow gear.
Older wide gear is possible to order some parts.
Buy some good quality snap rings pliers and read the manual that is also on line. Pretty easy to work on.
James Schaechter 3163 STK
