Liked 1,144 Times in 354 Posts
Has anyone use a Felpro 1043 head gasket with any luck on a 624 cast head? 4.080 bore .038 compressed thickness. I have a set I would like to use on my I/S 350 motor. Will buy Cometic if these are not a good choice. They say Aluminum heads or Vortec style combustion chamber, not for cast OEM heads. I have read on other forums where they claim they have used them on OEM cast heads successfully .
Thanks Randy Wells I/S 5628 Last edited by Randy Wells; 02-06-2021 at 01:40 PM. |
Liked 336 Times in 183 Posts
will not fit conventional OEM type combustion chambers---according to FELPRO for small chambered aluminum race heads some Vortecs sometimes used for uneven head or block surfaces
Liked 557 Times in 217 Posts
Lay the gaskets on the block dowel pins. If the sealing ring hangs into the bore at all I wouldn’t use them.
Put dowel pins in the heads and lay the gasket on the pins. See how it fits the chamber shape. That should be all you need to do to see if they can be used.
#4 | |
I did that, the gasket clears the bore and the combustion chamber, the fire ring on the 1043 is pre-compressed for aluminum heads. Maybe that is the issue with steel on steel. The fire ring is not as wide as a 1003 gasket. I think I will order a set of Cometic gaskets just to be on the safe side. Thanks Randy Wells I/S 5628 |
#5 | |
Liked 983 Times in 314 Posts
