Old 12-08-2020, 05:28 PM   #1
LS1Racer
LS1Racer's Avatar
Liked 6 Times in 6 Posts
Default 16 volt system with alternator.
I wanted to get some input on a 16 volt system with alternator. Late model F body stocker with 16 volt batteries and powermaster XS alternator. I also have a voltage step down box 25 amp continuous. My question is if the components will handle the 18.6 volts while charging. I realize the gauge lights and small things will need to be stepped down but what about the injectors, starter, Fast XFI ECU, MSD7AL,e shift and valve body,etc.I have heard those components will have no issue at 16v but not sure with the added charging volts Thanks in advance for any help.
LS1Racer is offline   Reply With Quote
Old 12-08-2020, 06:12 PM   #2
jamie2370
Liked 239 Times in 90 Posts
Default Re: 16 volt system with alternator.
Save yourself the trouble and please shut off the master switch when charging the batteries. If the charger spikes, it will take out all kinds of stuff
jamie2370 is offline   Reply With Quote
Old 12-08-2020, 06:15 PM   #3
jamie2370
the alternator should not charge voltage that high. If it does check to see if it is adjustable. Anything over 18 will likely spike a Fast ecu driver
Old 12-08-2020, 07:02 PM   #4
LS1Racer
LS1Racer's Avatar
That voltage is what I have read online. Alternator is adjustable from 13.5 to 18.6. My thoughts were to set to 16 volts and charge between rounds with switch off. I figured anything much above 16v would start frying things. Manufacturer of Electric fan (Deraile) states it will burn up at 16v.
Old 12-09-2020, 12:34 PM   #5
bykr
Liked 167 Times in 81 Posts
I always start charging while cooling the engine using the water pump and an electric fan and have never had an issue for years. If fans fried at 16v no one would be running one with a 16v system as normal full charge voltage is almost 17v.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 12-09-2020, 08:34 PM   #6
LS1Racer
LS1Racer's Avatar
I realize that point. My main question was at what point of voltage would you be concerned about component damage running with an alternator to charge the batteries.
Old 12-08-2020, 06:21 PM   #7
Robin Lawrence
Sponsor
Liked 717 Times in 121 Posts
This is what we have seen cause issues. the charger is at 20+ volts and when the starter turns over it can send voltage spikes into the ECU.
Turning off the charger while cranking solves this.
Some smart coils (IG1A) have issues over 17 volts. They can shut off. Most of the GM smart coils are ok.
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
