Old 12-05-2020, 07:12 PM   #1
monte8616
Liked 14 Times in 6 Posts
Unhappy LOST 10mph AND ABOUT 6 TENTHS
So, I have gremlins in my car... the motor is fine on the dyno, the MSD and coil from the car are fine on the dyno... the trans is fine - the converter has been sent out and is fine... has anyone had any issues with a Racepak causing an issue like this?? It’s really the only change we made over the winter... car made a few good passes and then lost the time and speed... it’s quite a discouraging problem - if anyone has any ideas, please help!! Thanks!
Joey Cole - GT/DA - 454 BBC - Turbo 350
monte8616 is offline   Reply With Quote
Old 12-05-2020, 07:37 PM   #2
MR DERBY CITY
Liked 8,250 Times in 1,542 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
Check fuel system, , the 30 second jug test is a good start, replace the battery/batteries....Have you done any welding close to the car ? .....Some racers have reported that their car became MAGNETIZED and they lost plenty of ET and MPH ......3 ideas to PONDER ......
Old 12-05-2020, 08:52 PM   #3
monte8616
What else do you know about the magnetized thing? Very interesting...
Old 12-05-2020, 09:00 PM   #4
Jeff Stout
Liked 708 Times in 285 Posts
I know a local racer that determined the spun bearings came from arcing on crank to bearing clearance and made pit mark's on journal. He had connected ground to block and welded on frame.
Old 12-05-2020, 11:48 PM   #5
MR DERBY CITY
When I weld on my car I ALWAYS disconnect my MSD and all grounds to the engine block. Jerry Doughty from Louisiana was the racer that had to DE MAGNETIZE his stocker. Perhaps him or his brothers could jump in here on this thread. I remember it involved a compass and a cell phone ...his stocker had the same symptoms as your car....
Old 12-06-2020, 10:09 AM   #6
monte8616
I don’t think anything was in the car when we welded but still a good thought - thank you! Nothing is a bad idea at this point!
Old 12-06-2020, 11:01 AM   #7
Greg Hill
Liked 279 Times in 68 Posts
Is this a Quadrajet motor or Holley? If it’s a q-jet I would bet money it’s in the fuel system.
It’s critical to have enough fuel volume and a q-jet on a 454 SS motor would really stress your fuel system. A good pump like a Magnafuel, a #10 line from the cell to the regulator, appropriate return line, and a # 8 line from the regulator to the carb would ne required. Even if it’s a Holley I would do the same thing.
Greg Hill 4171 STK
Old 12-06-2020, 07:19 PM   #8
HP HUNTER
Liked 373 Times in 129 Posts
Make sure the dist pickup wire is away from the other wires, I use a shielded pick up wire.
Old 12-06-2020, 08:33 PM   #9
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: LOST 10mph AND ABOUT 6 TENTHS
our car slowed down over a couple of races. Turns out it was the rubber brake line to the rearend swapped out line at track and picked up instant 5 tenths.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 12-06-2020, 10:03 PM   #10
4543
Liked 649 Times in 140 Posts
Can you post a net slip from both a fast and slow run? Can you post the race pack info from a good run with a bad one overlaid on it? What sensors do you have on the trace pack? Other thing would be send the race pack files from a good run and a slow one to someone you know who has been using a race pack for a while. Might pick up something.
4543 is offline   Reply With Quote
