Old 08-14-2020, 10:29 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,390 Times in 506 Posts
Default Wire Shielding EMI or RF Noise?
I am still having issues with erratic tach signal at high rpm in the data log and I even see it on the tach as well. My data logs have always been very choppy and jagged which makes the ECU do crazy things and even hits rev limiter which I have set very high.
I shielded my trigger wire that goes from ECU to Crane ignition box. I make sure to keep Magnecor wires away from sensor wires. Some distributor power and trigger wires DO pass by the alternator which makes me wonder if that is an issue. I have checked all grounds, made new grounds, use dielectric grease on plugs and boots, not sure what else to do.
I am told it could just be the nature of a dual-sync distributor that gets its crank signal using the hall effect and harmonics involved but I would like to know which other wires may need shielding.
'65 Mustang SS/L & L/SA
Old 08-14-2020, 01:00 PM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: Wire Shielding EMI or RF Noise?
I think that I would completely eliminate the alternator first. Belt off, wires off and isolated make run and see what it does. Maybe install extra grounds. Start with one from ignition box chassis to known ground. And do t trust any grounds! Us the “tug test” on every connection ground and hot. Steel wool all terminals and where they connect.
Painter is offline   Reply With Quote
Old 08-14-2020, 09:01 PM   #3
SS3860
Liked 179 Times in 60 Posts
Electric fans are a good source for interference also. Separate all ignition wiring from fan wires.
SS3860 is offline   Reply With Quote
Old 08-14-2020, 09:12 PM   #4
Keith 944
Keith 944's Avatar
Liked 1,887 Times in 579 Posts
Try a 10k ohm 1/2 watt resistor in tach wire
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 08-15-2020, 12:03 AM   #5
CMcAllister
Liked 931 Times in 265 Posts
I keep ignition wiring and "dirty" lines (alternator, fans & motors) separated as far apart as possible. And twist or braid the ignition trigger wires.
All grounds are connected to the ground post of the battery with copper - wires, cables. Don't rely on sheet metal.
Would be interesting to see what happens if the alternator is not functioning on a pass.
Old 08-15-2020, 12:12 AM   #6
FED 387
Liked 336 Times in 183 Posts
try grounding the head to the block and the block to the frame or body with the old style braided ground straps--NEVER use solid core wire for ground wire --if you do use braided wire make sure it is of sufficient gauge and not only crimped but put a bit of solder on the wire and connecter crimp area to make sure it is really grounded ---
