Old 07-10-2020, 04:16 PM   #1
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Hoosier radial drag slick
Running a 30x9R15. How many passes are the slicks
good for? Do they just start dropping 60ft ?
Have problem of hooking for 3 or 4 passes then out of
The blue the car will just blow the tires off at the hit.
Thanks.
David
Willyracer is offline   Reply With Quote
Old 07-10-2020, 07:11 PM   #2
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Default Re: Hoosier radial drag slick
I run a 30.0-10.5/15 Hoosier, and I have found the sidewall will go away before the tread surface is gone. I had a set at 45 runs that would not hook off the line, just spun. Mounted a new set and the car was fine. The set I have on now has about 60 runs on, and last time out the 60 ft. was very consistent in some very bad air. I rotate them side to side at 25 runs. The car is 3150 lbs. and I hit the tires pretty hard, so I guess they don't last as long.
Patric Fox is offline   Reply With Quote
Old 07-10-2020, 07:34 PM   #3
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
We have run the 9 inch Hoosier for the last 6-7 years. We get 75-80 runs out of a set. Other folks claim to get 150 runs. We have tried very short burnouts, but that did not change the tire life for us.
Our 60 foot times remain the same throughout the life of the tire. On one set of tires we ran them a bit too long. After a pass there was a one inch wide stripe of cord showing in the middle of the tire. OOPS! 60 foot time on that run was same as before.
For reference our car runs 11.0s with mid 1.40 60 foot times.
Larry Merk
Larry Merk is offline   Reply With Quote
Old 07-10-2020, 07:31 PM   #4
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Thanks.
David
how many passes do you have on them ?
Old 07-10-2020, 09:18 PM   #5
Willyracer
Willyracer's Avatar
Less than 40 passes
Old 07-10-2020, 09:23 PM   #6
Willyracer
Willyracer's Avatar
The car is a A/SA 3650 lbs
we run 21 psi
On the burn out I do just 1-2 no 3rd
Thanks for all the feedback
David
Old 07-11-2020, 06:11 AM   #7
Alan Nyhus
Liked 799 Times in 236 Posts
The car is a A/SA. 3650 lbs. We run 21 psi. On the burn out I do just 1-2 no 3rd. Thanks for all the feedback. David
Are they the CO6 or CO7 compound?
"That'll never work....."
Old 07-11-2020, 09:58 AM   #8
Willyracer
Willyracer's Avatar
C06 coumpound
Old 07-10-2020, 08:51 PM   #9
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Thanks.
David
On my dakota, same stocker tire, I tend to keep them on for 125 or so runs. Now if you run them till the end, right before they get to the cords, they will be there fastest.
Dragpak when it had the auto, I think I got it up to 75-80 runs, took a set or two to learn to do a 1-2-3 done burnout.
Re the 3-4 then blow tires loose, well it did it, but it was leaking water from a hose clamp.
Good luck
Don't know how heavy your car is, but if you are on the edge with a lot of tire pressure, that could be an issue with your blowing them loose issue as well. On the truck I run 21.5 which is a soft setting for it. I have run as high as 25.5, but have spun at the pressure as well, have never spun at 21.5, unless track was wet.
Eric
Eric Merryfield 1883 STK
Old 07-11-2020, 12:59 PM   #10
Glenn Briglio
Glenn Briglio's Avatar
Liked 971 Times in 308 Posts
Thanks.
David
Light weight or standard radial?
