Liked 9 Times in 5 Posts
Does anyone here run amsoil in their stock/superstocker? What weight? I picked up a sponsor from a small amsoil rep and he wants me to try some. I have never used any amsoil products so any info would be great, thank you
Liked 171 Times in 36 Posts
I've been having good luck with the Amsoil 10w-30 synthetic Dominator race oil in my Super Stock 427. Other than a rod bearing issue I had last year, which was not due to the oil I am using, the bearings look perfect every time it's apart. I also use their synthetic ATF and gear lube with good results.
Liked 819 Times in 342 Posts
I have never used it but member "Locomotion" has used it for years and should have a meaningful response when he sees this.
Liked 91 Times in 29 Posts
The first thing about having Amsoil as a sponsor is making sure you spell their name correctly. LOL . That being said I have used their products for years in my Race quads and sleds. Also have used their assembly lube in engines.
Bruce Cameron 68 Nova 396 E/S 68 Camaro SS/? ex Checkmate Modified |
Liked 265 Times in 69 Posts
Great oil, I use 10w30 in my stocker
John Dinkel 3295 STK |
Liked 1,072 Times in 379 Posts
We have ran it for a long time. Actually had the oil pump pick up break off and made entire 7800 rpm dyno pull with 10 psi pressure and the bearings looked new. Yes, the dyno operator was a bit red faced, but it turned out alright. That's what really sold us on it. We use the 10-30 Dominator, but I know some people with tighter bearing clearances than us run the Dominator 20w all the time. I've been told its slower than most oils on the dyno, but if your looking for protection, its a great choice.
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 01-19-2020 at 08:22 PM. |
