Old 01-03-2020, 03:00 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Oil pre-heater
I just got a couple Moroso 23991 400 watt probe type heaters and I've been told they can scorch the oil. I notice that the Stefs is a much lower wattage. Which oil/trans oil heater do you use? Thanks for your advice.
Ron Gusack is offline   Reply With Quote
Old 01-03-2020, 03:09 PM   #2
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Oil pre-heater
For engine oil, a Kats watt magnetic heater...steel pan, of course. For the trans, a Zero Start heater with a 1/2 NPT bung welded to the trans pan. -Al
"That'll never work....."
Old 01-03-2020, 05:04 PM   #3
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
Got a few of the Kats 300 watt magnetic heaters. Gonna have to get something different for the EF/S car, Aluminum pan.
Dave Noll, EF/S ,?/SA 6526
Old 01-03-2020, 06:30 PM   #4
Shadylane
Shadylane's Avatar
Liked 168 Times in 50 Posts
I’ve used the Moroso external heating pad for a couple years now. Takes about 30 minutes to heat the oil. Sticks on, they have different sizes or a model that attaches with springs.
Moroso 23996 - Moroso External Heating Pads
Kelly
Shadylane is offline   Reply With Quote
Old 01-03-2020, 11:41 PM   #5
Ron Gusack
Ron Gusack's Avatar
I'll check these out Alan, thanks
Old 01-04-2020, 01:48 AM   #6
FED 387
Liked 329 Times in 177 Posts
Definitely look at the Stef's heaters ---either the pad or the in the pan style---the in the pan style is for use in OILS --the Moroso style heater is for WATER---Go to Stef's website read about their products--- other suppliers may make a similar product but the Stef's style will not scorch the oil because of its design---the only difference between using it in a steel or aluminum pan is the bung that you weld into the pan steel for a steel pan and aluminum for an aluminum pan-- FED 387
Old 01-04-2020, 01:07 PM   #7
Ron Gusack
Ron Gusack's Avatar
If it's for water they shouldn't market it for oil. This is directly from the Moroso website (notice the 212 and 400 watts of power statement):
Heater element designed specifically for heating oil; does not scorch or boil like "converted water heater" designs
212 watts of power raises temperature of 12 quarts of oil 60 degrees F in about 25 minutes
400 watts of power, 110-120 volt rating
Aluminum, 1/2" -14 NPT weld-in bungh and 3 ft. cord included
Length of heating element is 4-3/4" from fitting to tip
Old 01-04-2020, 03:23 PM   #8
FED 387
I know which one I'd use and it's the same one we have used in multiple engines--As far as the pads go we have used them ONLY to preheat the differential never the oil pan itself-- Your choice use what you like if it works great for your application terrific. AS LONG as you use the type that is totally sealed unlike the one in the picture you should be OK also remember the "2 piece" type the connector has a habit of loosening up and you have to be aware of this constantly check to make sure its screwed on tight ---FED 387
Old 01-03-2020, 06:47 PM   #9
jmantle
Liked 169 Times in 80 Posts
We put heaters in the oil pans and hydraulic tanks of heavy equipment on a regular basis, the general rule was no more than 10 watts per square inch of heating element. High wattage units made for water will cook the oil. More info here, https://www.warrenelectriccorp.com/a...rs/default.asp
Jim Mantle V/SA 6632
jmantle is online now   Reply With Quote
Old 01-03-2020, 08:56 PM   #10
bykr
Liked 167 Times in 81 Posts
I siliconed the Moroso heater to the bottom of my aluminum pan worked great, but would leave it on for only about 30-45 minutes.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
