Liked 115 Times in 35 Posts
Looking at the cylinder head cc the 461x is listed as 172cc intake and 64cc exhaust. All others are 165cc and 65cc. But then there is a note that says port volumes based on "X" head. Does this mean for example a 041 head can be 172cc intake port?
Also what is the best intake to use? I have a 3875954. |
Liked 250 Times in 49 Posts
The only 461x heads that I have seen came off of vette engines. They all had 2.02 intakes and 1.60 exhausts. The chamber is slightly different from the 461, supplying extra clearance around the valves. Looks like it would be a huge advantage on the 275 hp engine if you replace the seats to use the smaller valves. Pete
Liked 784 Times in 196 Posts
I have harvested several sets of 461X heads off early 1962 327-300hp engines.1.94 & 1.50 valves.
Liked 2 Times in 2 Posts
[QUOTE=Dwight Southerland;602996]I have harvested several sets of 461X heads off early 1962 327-300hp engines.1.94 & 1.50 valves.[/QUOTE
I have seen the same 461X heads on 62 327/300 hp engines and with the small valves.
1969 camaro, pump gas 540"bbc, jerico 1967 camaro, pump gas efi 620", coan t-400 |
Liked 373 Times in 129 Posts
Never seen a 461 X with 2.020/1.60 Valves. Always 1.940/1.50.
Liked 557 Times in 217 Posts
There were really very few small blocks that came with 2.020 and 1.600 valves, OEM...compared to the millions of engines built over the years
I also never saw any 461x heads with anything but 1.940 and 1.500 valves myself. Many of the real early 1960’s castings were somewhat poor quality. Material seemed soft and the head bolt bosses were easily damaged. Splits, cracks and other flaws were pretty common. Used to see spots that were welded by the factory occasionally to save a casting. Valve cover rail , deck, head bolt boss.
Liked 28 Times in 15 Posts
What are your typical 462, 461, 041 heads worth these days? Anybody buy/sell these things lately?
Liked 727 Times in 221 Posts
461 heads are only legal on pre-67 cars. That narrows their applicability. 462 heads are legal all the way back to '62 327's. They came out in '67 and 68. The 041 head came out in 69 and 70 only. There were probably more of those made than 462's. It's legal to use the 041 head on '62 on up 327's in place of the 461-462 head.
As with anything else, condition dictates value. A set of castings that have never been apart are definitely worth more than a head the has gone to too many parts store back room valve jobs. Also, some back yard port jobs rendered a lot of heads useless in their aftermath as far as their future legality. A very nice set of 462 or 041 heads could be worth up to $350-400, that is one with original guides, valve seats, deck surfaces, no overheat damage, and untouched ports. That gives a good cylinder head guy a good place to start. The worn out stuff could go to those building a bracket car or a cruise night special rather than a legal car. It would seem like a waste to sell very nice original castings to somebody to use to go ruckety-rump through the drive ins with. One thing about heads, blocks,and intakes, all this stuff made prior to the '70 model year, when many of us were in high school, is all 50 years old now. Seems hard to believe, but it's true. When we were in school and all this stuff came out new, a 50 year old car was a Model T. Used cores that are serviceable should be worth around $100 on up. |
