Old 10-07-2019, 10:59 PM   #1
camaroinmotion
Liked 6 Times in 3 Posts
Default BBC 049 oval port heads. question
Next year bracket car project .. planning to install them on a 496 CI... What valve be useful. 2.18/1.88. Or can I fit a 2.25/188... No limited to class.... compression ???....do I used a open chamber or closed chamber piston... Thanks all for help
camaroinmotion is offline   Reply With Quote
Old 10-11-2019, 07:18 PM   #2
camaroinmotion
Default Re: BBC 049 oval port heads. question
Can get any help from 1 person?????
Old 10-11-2019, 07:47 PM   #3
HP HUNTER
Liked 373 Times in 129 Posts
You will use a open chamber piston. The head will have to be clearanced back behind the exhaust valve to clear most pistons.
Example:
Name:	vp chamber 236.jpg
Old 10-11-2019, 08:56 PM   #4
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
Years ago I ran a 468ci with 049 heads w/ 2.19" & 1.88" valves,.680 lift solid roller cam, Speed Pro 7040PA pistons, Fel Pro .039 head gaskets and 850 cfm Holley, ran strong. Camaro that was approx 3000 lbs with me on board, 3500 rpm converter, solidly mid 10's. IIRC intake was Strip Dominator oval port.
