Old 09-09-2019, 11:55 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Smile engine angle
putting together a second gen Camaro and when the motor is in , its higher in the rear, I'm sure the back should be lower but how many degrees ?
Mike Savelle is offline   Reply With Quote
Old 09-09-2019, 12:15 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: engine angle
I've heard that the carb base should be level. Most manifolds are cut to slope down (I think 4 degrees).
Here's an interesting article from On All Cylinders regarding Jerry Bickel. It's not a Stocker, though.
https://www.onallcylinders.com/2016/...s-drag-racing/
Dale Shearon
68 Mustang 6394
Old 09-12-2019, 06:58 PM   #3
Chevy55
Banned
Liked 179 Times in 89 Posts
There's two things to consider, one is the driveline angle and the other is that the engine is at least one degree up from level in the front so you don't get air trapped in the engine when filling with coolant.
https://www.iedls.com/uploads/files/...in%20Setup.pdf
Chevy55 is offline   Reply With Quote
Old 09-12-2019, 11:31 PM   #4
FireSale
FireSale's Avatar
Nice little guide. I need to redo the pinion angle of my Mustang over the Winter and this will help.
Dale Shearon
68 Mustang 6394
Old 09-13-2019, 11:21 AM   #5
Dave Gantz
Liked 251 Times in 125 Posts
That is nice. I'm putting a 9" Ferd w/ladder bars in a Duster. That should help a bunch.
Old 09-13-2019, 07:51 PM   #6
CMcAllister
Liked 920 Times in 259 Posts
If this is a typical big tire backhalf car with the rear u-joint CL higher in the car than the front joint CL, having the engine nose down will help achieve desired operating angles on the joints while keeping the pinion angle negative or nose down - which is desired in a drag car.
Otherwise, using the OE engine 3 degree down in the rear mounting, you get into the "broken back" arraignment.
Plus, the oil pan, headers, steering, etc all have to fit each other. It takes some planing and time mocking things up.
