Old 06-10-2019, 09:10 PM   #1
R5ROB
R5ROB's Avatar
Default Power rack n electric pump drag pak
My drag pak has a manual rack in it
Anyone switch there’s back to a electric power rack and what pump did u use
The stock challenger or go with a after market pump
Thanks
R5ROB is offline   Reply With Quote
Old 06-11-2019, 11:53 AM   #2
340Cuda
Liked 805 Times in 341 Posts
Default Re: Power rack n electric pump drag pak
Check with Jeff Teuton, he has done this. I think there is a thread here about it.
340Cuda is online now   Reply With Quote
Old 06-11-2019, 05:06 PM   #3
R5ROB
R5ROB's Avatar
I did a search but didn’t find anything
Old 06-11-2019, 08:56 PM   #4
mike britt
Liked 66 Times in 31 Posts
I would leave the manual rack in it and put and electric column out of a Toyota in it. You'll also need the P/S ECU.
mike britt is offline   Reply With Quote
Old 06-11-2019, 09:15 PM   #5
340Cuda
http://classracer.com/classforum/showthread.php?t=71542
I think this is it...
Old 06-12-2019, 05:53 AM   #6
R5ROB
R5ROB's Avatar
Pretty sure I found the problem
The stock joint out of the column is starting to twist and binding up and has really tight spots as it’s wobbling as I turn it
Time to tool up a new column for it
Old 06-12-2019, 09:18 AM   #7
MPR
Liked 23 Times in 8 Posts
The early Drag Pak Challenger (LC Platform) use the column with the articulating joint and a production rack & pinion with no power valving installed. This steering rack has a stock ratio and requires lots of input effort so it's hard to steer. The later Drag Pak cars (LA Platform) use a steering column with a typical slip shaft instead of the articulating joint. Flaming River makes a replacement rack & pinion PN FR1515MPR16 which requires a fabricated steering intermediate shaft which adapts the LA column to the Flaming River rack. This is the setup which all of the latest Drag Paks were built with and solve all of the issues with the setup that came on the LC platform cars.
MPR is offline   Reply With Quote
