Old 06-07-2019, 10:25 AM   #1
sean1970ss
Liked 10 Times in 6 Posts
Default High rpm 427 bbc build 940hp?
I was talking with a guy he said they dynoed a 427 bbc here while back made 940hp at 9200rpm. .100 over, 14.1 compression .903 lifter, 55mm cam light pistons, and rods tunnel ram. AFR 315 heads 2.300 valve.
Is that possible??? Never seen one make that much power.
sean1970ss is offline   Reply With Quote
Old 06-11-2019, 09:12 AM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: High rpm 427 bbc build 940hp?
Sure it is.
Old 06-11-2019, 12:20 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Built like an old school A/ Modified Production engine.
Some small inch Big Blocks with 348 cranks made near that turning well over 10K RPM's
Old 06-11-2019, 02:06 PM   #4
Hacksaw
Liked 314 Times in 177 Posts
Wonder what a J. Armstrong Super Stock engine with a tunnel ram bolted to it would make?
Old 06-11-2019, 06:29 PM   #5
Dana Fitzpatrick
I've wondered that myself.One step further,set up some match races against the SS/AH cars.And throw in some SS/A Fords.I'd pay to watch.
Dana Fitzpatrick is offline   Reply With Quote
Old 06-11-2019, 06:58 PM   #6
Dick Butler
Liked 32 Times in 19 Posts
Chrysler would pass a rule...
Old 06-11-2019, 08:31 PM   #7
HP HUNTER
Liked 373 Times in 129 Posts
Thats a very good question!
Old 06-21-2019, 11:11 PM   #8
Jim Hawkins
Liked 115 Times in 35 Posts
Back about 1985 had a 420" big block in a 69 nova for SS/BM. Had a crower crank made at 3.60 stroke, alum. rods, alum. bow tie heads, titanium valves, cast tunnel ram and 2 dominators. That motor saw 8500rpm and ran a best of 9.59 at pomona. Really should have run quicker and made more power than it did but we did manage to win the mile high's with it in 1989.
The motor is still in the car owners garage just as we ran it back then. Dominators and all, and he would like to sell it.
Jim Hawkins is offline   Reply With Quote
Old 07-09-2019, 11:17 AM   #9
joespanova
Liked 13 Times in 11 Posts
I'd like to look at those heads , because its highly unlikely , no , make that definitely NOT anything close to what AFR produced...so this suggestion is somewhat "misleading". The only thing AFR 315 about those heads is the casting. Contemporary t-ram / carbs , vac pump and all the other bells and whistles .....
Old 07-10-2019, 03:22 PM   #10
sean1970ss
Tony Mamo did the heads. Never witnessed it or had anything to do with it.
