Old 05-10-2019, 07:34 PM   #1
Greg Stump
Default 1972 Stock Suspension Nova
• 555ci pump gas BBC professionally built with little run time & never raced
• F2 Procharger, Big Red blowoff, cog drive, CSU 1150 blow through carb, & Dart powder coated intake
• Dart tall deck, O-ringed copper head gaskets, ARP head studs
• Callies crankshaft, JE pistons, Eagle rods L-19 bolts, Hellfire rings
• Dart 360 cylinder heads, CNC ported Indy Head Service
• Steve Morris/Comp Cam, Procharger special grind +800 lift
• Jesel valve train, belt drive & Crower lifters
• ATI 6-Bolt dual key blower Damper
• Moroso valve covers
• CSI electric water pump
• 2 ½” x 5” coated Lemons headers & 5” Mountain Motor Mufflers with turndowns
• MSD 7531 Digital Ignition
• Powerglide/ 1.76 gearset, Vasco Input, Alto clutches & steels, Kevler band, TCI protree trans brake, B&M shield & shifter
• 9” rear/3.70 gear, stock center, Moser 33 spline axles & spool, 5/8” wheel studs
• Inland Empire aluminum drive shaft
• Stock suspension all steel car (fiberglass hood)
• Full stock interior, front bench seat
• Mini tubbed utilizing stock wheel tubs
• Calvert split mono leaf springs & Caltrac Bars, QA1 single adj. shocks
• Balistic Fab leaf spring mounts
• Rear leaf spring sliders
• Weld Alumastar wheels 15x10 & 15x3 ½
• Stock front suspension completely rebuilt, Comp 3 way shocks
• 4 wheel disc brakes, cross drilled & slotted front rotors
• 15 Gal fuel cell with sender, Magna Fuel 500 pump & filter, Aeromotive regulator
• 1000 CCA battery with remote disconnect
• Aluminum dual pass radiator with dual fans
• Current NHRA Cert. 4130 cage (very nice)
• Car is jammed in with Lambrogini Green Paint with smoothed fire wall. Exterior is currently Satin Black sealer.
• AWESOME KICKASS Licensed & Insured Car with Title, not perfect but very nice. $39500
717-440-4195
Greg Stump is offline   Reply With Quote
Search this Thread:
Advanced Search
