Old 03-19-2019, 10:31 PM   #1
Jim Whitehead
Liked 150 Times in 41 Posts
Default Fast computer & Data logger Question
I have a original Fast system with external Fast ecu data logger, i am trying to hook up the data logger. I know the arming wire and trigger wire need to be grounded to work. My question is can the trigger wire be hooked up to a momentary switch to ground, or does it need to stay grounded for the entire run for it to log. I called Fast and they could not answer my question, I was told they do not remember on the old system. Thanks in advance Jim.
Jim Whitehead is offline   Reply With Quote
Old 03-20-2019, 08:35 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Fast computer & Data logger Question
Jim, every system I have used logged while the logging switch was "on". At the finish line you turn the switch off, to end log. I guess you could use a button to log while you hold it down.
Ed Wright 4156 SS/JA
Old 03-20-2019, 08:40 AM   #3
Rsmith38
Liked 28 Times in 15 Posts
Jim they bought the data logger -didn't even make it! Both units obsolete - and no one there can help. I don't have the book available but I never had a momentary switch so a constant ground works. I turned it on at staging and off after finish line. Believe it runs for a 60 second time -
Rsmith38 is offline   Reply With Quote
Old 03-20-2019, 09:40 AM   #4
Ed Wright
Ed Wright's Avatar
I use the FAST XFI with the internal data logger. I turn the logger on at the I pre-stage light, and back off at the finish line.
Old 03-20-2019, 10:09 AM   #5
Jim Whitehead
Thanks for the replies guys. I talked to Matt Maxwell at Fast he sent me instructions. I know i can just put it on a toggle to ground but wanted to arm it with one switch and then trigger with another when ready to log. Just thinking i do not need to see all the staging data, or waiting on someone else to stage. Thanks again
Old 03-20-2019, 08:20 PM   #6
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Smile Re: Fast computer & Data logger Question
Perhaps Jim, but if/when you let the kid/kids drive it, its good to know when crimes of the water box have been committed.....and even if no crime, you can critique the rpms, time, etc....for mine, the girl was the valve spring tester, the boy for some reason had a hard time with race track burnout......not so in the school parking lot.
Eric
Eric Merryfield 1883 STK
Old 03-20-2019, 10:32 PM   #7
Ed Wright
Ed Wright's Avatar
All you do is set the %TPS & RPM for the logs to start. Don't have to see the burnout, unless you want to. My logs start @6000 RPM, if the TPS is at 100%. MY converter flashes to 6400, so I see everything I need to.
Old 03-20-2019, 11:03 PM   #8
mike britt
Liked 66 Times in 31 Posts
I have the classic FAST and I called them today and they couldn't tell me how to wire the data logger. They did tell me that the diagram for it is in the software in the ecu. I was told to hook up my laptop and there would be a dropdown for wiring schematics.
mike britt is offline   Reply With Quote
