Old 09-24-2007, 08:42 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Batterey Kill Switch
Need a little clairification please.
I'm looking at the different kill switch's and there are two and four posts.
The four post is supposed to be for running a alt and the two post is for no alt.
If you are cutting into the positive battery cable from the battery in the trunk does it
matter which one you use?
I have a alt and the battery is in the back. Which one would be correct?? Is more posts better??
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 09-24-2007, 10:19 PM   #2
Mike Hedger
Default Re: Batterey Kill Switch
Buy the four post and run your alt. through it. It will kill all of the power to the alt. unlike the two post it only shuts off the power to the rest of the car. Hope this helps, Mike
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
Old 09-25-2007, 08:45 AM   #3
Dave Goob Cook
Dave Goob Cook's Avatar
The battery switch must kill the engine when switched off, so if you do run an alternator, you have to wire the alternator through the switch as well, so the 4 post switch is the best/easiest choice.
Dave Goob Cook is offline   Reply With Quote
Old 09-25-2007, 09:47 AM   #4
junior barns
Liked 20 Times in 14 Posts
dumb question here but why couldnt you run your alt wire on the same side as the hot off the battery to the switch??
junior barns is offline   Reply With Quote
Old 09-25-2007, 11:12 AM   #5
Dave Goob Cook
You can easily do that, but it will kill your battery if a diode fails in the alternator.
I like knowing that all the wiring is dead when the switch is in the off position also.
Old 09-25-2007, 11:46 PM   #6
Philip Saran
Thanks for the replys to my question. Now I can move forward and know what I'm doing is correct.
Phil Saran
Parker, Colorado
