Liked 1,002 Times in 203 Posts
Planning the build for my next 265 Stocker motor.Will using a 305 block with the spacer bearings like I did for the first one.Are there any 305 blocks(cant afford a Bow tie) that are better to use than others? I will be boring it .060 (3.790).Thanks for the info.
Liked 485 Times in 160 Posts
This Ebay seller has a few of these blocks both 0.040" and 0.060" O.S. for sale.
https://www.ebay.com/itm/Small-Block...-/172866626342 |
Why does that guy have so many 305 blocks with no main caps??Another question is it a must to pour a 305 block?
#5 | |
Liked 18 Times in 10 Posts
.060 Over blocks you my want to sonic test before you buy it. |
Liked 49 Times in 15 Posts
You may want to check with tech on the legality of a 4 bolt block. Back when my engines were built, I was told by Div 5 that a 4 bolt was not legal, only 2 bolt. But, that was a long time ago and things have certainly changed.
The eBay add states the block is bored and finshed honed. Um, how is that possible without caps on it. While I'm no machinist, I don't think I've ever heard of a block being bored and honed without caps on it. Buying that eBay block, then adding caps to it, and then working out the bore will not be "cost effective". If your going to spend that kind of money, I would recommend you sleeve a larger bore block or go aftermarket. I have a 350 sleeved and a 307 sleeved. The 307 block I used was an early model, cast in a 350 mold. It had very thick walls to start and then got 8 sleeves. Very good piece.
Dean Feiock -- Stock 5002 Last edited by Dean Feiock; 11-27-2018 at 11:25 PM. |
I will be staying away from the exotic 4 bolt main blocks,and the sleeved blocks because of the cost.I guess I just need to find a good used standard bore 305 block.Will check around here locally.Thanks for the info.
Liked 5 Times in 3 Posts
Lynn,
Talk to Bob Downing. I'm sure they have a barn full of them.
Bruce Witherspoon 3656 SS/KA |
Liked 166 Times in 71 Posts
The 1996-2000 305 vortec blocks are supposed to be the best, but you would have to use a rear main seal adapter, just like many of the bowtie blocks had.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
