Old 07-08-2018, 08:30 PM   #1
Tex013
Liked 48 Times in 27 Posts
Default 65 Malibu rear control arm angle question
Hi ,
just trying to find some setup information for rear end in a 65 Malibu .
Has a Strange 9" bolt in . UMI adjustable upper bars , UMI fixed lower bars , 1"lowered UMI rear springs , Viking shocks .
Motor makes 460HP , 4800 stall vert , T400 , footbrake launch .
Currently :
upper bars are 9 degrees down
lower bars are 3 1/2 degrees up
pinion angle is 3 degrees down
Car has not been run yet . Is this a close enough to start point or way off base ?
Thanks in advance ,
Tex
Tex013 is offline   Reply With Quote
Old 07-09-2018, 12:01 AM   #2
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Default Re: 65 Malibu rear control arm angle question
Tex,
We downloaded the spreadsheet in the link below to help us get our 81 Malibu rear suspension setup and working correctly. We found it to be extremely helpful.
It is just as important to get the front suspension setup and working properly. If the front suspension isn't working in concert with the rear suspension, results will be less than desirable.
Good luck.
http://www.patooyee.com/calculators/4BarLinkV3.0c.xls
Larry Merk
Larry Merk is offline   Reply With Quote
Old 07-09-2018, 05:56 PM   #3
Tex013
Larry ,
thanks a lot I will give that a try
Tex
