Old 03-19-2018, 11:35 AM   #1
1320pro
Default Does Anyone Re-Certify an SFI Bellhousing
Hey Guys, I have a Ford C4 with an expired bellhousing. Does anyone re-certify them or do I have to buy new? I am unsure who the manufacturer is. It's on a '13 CJ.
1320pro is offline   Reply With Quote
Old 03-19-2018, 12:22 PM   #2
FED 387
Liked 336 Times in 183 Posts
Default Re: Does Anyone Re-Certify an SFI Bellhousing
Joel's on Joy was the OEM to Ford might give them a call--FED 387
Old 03-19-2018, 01:30 PM   #3
nhramnl
Liked 358 Times in 83 Posts
Talking Re: Does Anyone Re-Certify an SFI Bellhousing
I think Bill Diehl does that. Send him the bellhousing and $200.
Old 03-19-2018, 06:14 PM   #4
1320pro
Thanks Guys. Found out that it's a JW bell and I'm getting it sent to them.
Old 03-20-2018, 10:35 AM   #5
btrc
Liked 84 Times in 42 Posts
If you are running in a class that doesn't require a certified bell housing but you happen to use one does the certification need to be kept up to date?
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 03-20-2018, 11:24 AM   #6
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
At our track they require all cert’s per NHRA. If you are sub 9.99 why not just do it right and not have to worry anywhere you want to race/run?
Don’t forget about the case too Mike... or maybe you are going to run a blanket?
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 03-20-2018, 11:40 AM   #7
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
If you don't require a flexplate shield, then you can run with an expired SFI bellhousing.
S/ST 51
S/C 53
