02-05-2018, 07:29 PM | #1 |
NHRA fuel check
What are you Stock and Super Stock racers using for the required fuel check? New to Stock racing.
Thanks |
02-05-2018, 08:58 PM | #2 |
Liked 33 Times in 16 Posts
Re: NHRA fuel check
About as cheap as you will find and works... http://quartermax.com/fuel-sample-valve/
Rich Taylor I/SA - 321 |
02-06-2018, 02:10 PM | #3 | |
Liked 704 Times in 305 Posts
Re: NHRA fuel check
This looks like it just pulls a sample from the tank. Thanks, Bill |
02-06-2018, 03:09 PM | #4 |
Liked 1,702 Times in 520 Posts
Re: NHRA fuel check
That one mounts on the regulator. Push in and the fuel comes out of the tube. Release and it stops. Looks like a nice way to do the job. As far as I know you have to take the sample from under the hood.
Mike Pearson 2485 SS |
02-06-2018, 04:31 PM | #5 |
Re: NHRA fuel check
"Pumps/Valves: Cars equipped with carburetor(s) or nonelectronic
fuel (EFI) systems but with mechanical non-OEM fuel pumps must have a quick-action fuel-shutoff valve within easy reach of driver and located in the main fuel line between the fuel tank and the carburetor and/or injectors. Fuel recirculation systems not part of normal fuel/pump system prohibited. All cars in Stock, Super Stock, Competition, and Pro Stock must be equipped with a positive-lock drain valve located between the fuel tank and the carburetor(s) or fuel injector to facilitate removal of fuel samples for fuel-check purposes."
02-06-2018, 04:37 PM | #6 |
Liked 21 Times in 13 Posts
Re: NHRA fuel check
Brian Carpenter Stock 1358 |
02-05-2018, 09:11 PM | #7 |
Re: NHRA fuel check
Thanks so much. Just ordered one.
Ron |
02-05-2018, 09:41 PM | #8 |
Liked 2 Times in 2 Posts
Re: NHRA fuel check
Just curious but what is the devise being used to check fuel for
chemical content or diaelectic spec.? |
02-06-2018, 10:10 AM | #9 |
Re: NHRA fuel check
Here's one w/o the hose: https://www.appliedracing.com/an-fit...ple-valve.html
and a brass one: https://www.mcmaster.com/#7910k11/=1bg9eu0
02-06-2018, 12:45 PM | #10 | |
Re: NHRA fuel check
