Old 10-17-2017, 10:21 AM   #1
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Metric 200 ? 200 vs.200-C
The THM 200 is a great choice to race with , light weight , good selection of aftermarket parts , fast . One question I have, is there is a difference in the spline location of the turbine shaft, and stator shaft of a 200 compared to a 200-C . The spline count is the same , but the earlier 200 which was made before 1981 did not have a convertor clutch , the 200-C was introduced for the 1981 model year and did have a convertor clutch . Stator shaft is quite different . What version of the transmission do most racers use ? Do the convertor builders make a convertor that will fit either version ? I have always concentrated on a 200-C because all the ills of the 200, was fixed in the 200-C , such as a improved servo , pump , gearsets , and deeper pan with improved filter . The aftermarket has fixed some other woes such as a pressed in stator shaft . Also aluminum drums and different gear ratios are available , trick auto shift valve bodies , etc . Just wondering if this stuff is all compatible between the 200 and 200-C .
Old 10-17-2017, 03:25 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 971 Times in 308 Posts
Default Re: Metric 200 ? 200 vs.200-C
Pm sent
Old 10-17-2017, 08:13 PM   #3
Liked 5,121 Times in 1,952 Posts
Russ, I was able to use the same converter on both transmissions, 99% of the time.
I worked with Scott McClay a bit on this.
You can get enough spline engagement on both splines. I would just cut the lock up nub off the input shaft. The 245 mm's are even easier, because the sprag race is relatively narrow.
Old 10-18-2017, 07:23 AM   #4
Glenn Briglio
Russ Pm sent
