Liked 58 Times in 16 Posts
Noticing high HP small tire cars going to beadlock type wheels but not so much in stock/super stock. Why not? The Small tire grudge guys run on radials too... Any advantage or disadvantage? Thinking on new wheels soon trying to think ahead...
Overkill is Under-rated |
#2 | |
Liked 1,583 Times in 582 Posts
The small tire guys run pseudo street radials and use beadlock wheel to stretch and keep the tire on the rim. Nevertheless, I have seen a few small tire guys go fast without beadlocks. Over than the "cool" look, as applicable to a Stock or Super Stock car, they are not necessary. They are also heavier and many drill the wheels and use screws to retain the tie to the rim in lieu of using beadlocks. Save your money and use standard lightweight wheels like everyone else. |
Liked 33 Times in 16 Posts
In my case I wanted a standard wheel for the El Camino like we have on the Camaro, but alas Champion Wheel will not build a non-beadlock rim anymore. I had already made my mind up for the Champions regardless...absolutely love the wheels.
Mine on the El Camino are single beadlock...can't say how much weight it added to the package. I can say it is a pleasure not needing a tire machine to install the tires. ![]() ![]() ![]()
Rich Taylor I/SA - 321 |
#4 | |
Guest
Posts: n/a
Thanks Stocker 396, I am looking at Beads.. |
#5 | |
If it was a safety issue, NHRA would have addressed the issue. I spent half a day with Rick Bogart of Bogart Wheels discussing racing wheels. The discussion went on his experiences from the manufacturing side and the input he gets from racing engineers and I share my experience as an aerospace engineer in the different types of aluminum material grades and treatments. The main problem with drag racing wheels is that racers always want to purchase the lightest wheel available without taking in to consideration the weight of the car. The correct rim wall thickness comes in to play and it is very important. This is the reason why Bogart Wheels has many different rim wall thicknesses for the same wheel designs and its use is based on the application. He learned his lessons from many wheels that in the past have cracked and got damaged from constant wheelstands on heavy cars such as Stock, Super Stock and bracket cars. Under a hard launch, if the rim wall thickness is not appropriate, the wheel will deflect and the tire bead will have the tendency to separate. It will also fatigue the wheel. As a matter of fact, any aluminum lightweight racing wheel will eventually suffer of fatigue due to use and cycles. When the wheels for my Comp Eliminator car were built, Rick showed me the difference between a Comp Eliminator dragster wheel when compared to the wall thickness he was going to use on my Super Modified car. Even when he builds wheels for a dragster, there is a difference on the wheel wall thickness between a V-8 and V-6 powered dragster. Still, if you want to go with Beadlocks, that's your and any other racer's prerogative. |
Liked 9 Times in 8 Posts
I was one of the first if not the first to have champion convert a set of welds to beadlocks back in 1999 on my outlaw 10.5 car...the reason...... they were 14" wide, and like said above the tire was "stretched" to fit. actually the shop owner were I worked part time thought the idea I was the guinea pig....of course all the "experts" said it would not work well...nevertheless, it became the norm for those types of cars over the years
__________________ Bill Diehl B200 C/D STK |
Liked 799 Times in 236 Posts
Weld offers a knurled finished lip when you can't or don't want to use screws. -Al
"That'll never work....." |
Liked 345 Times in 149 Posts
Whether or not the beadlocks is needed is personal choice imo.
I've been 1.12 60' on a 275 radial and no beadlocks. Never had an issue. I chose beadlocks so I could swap tires at home...convenience and a time saver. I've not seen a performance difference due to the weight of beadlocks. We're talking about 4 to 5 lbs more for a double beadlocks wheel. I've changed from one tire (24 lbs each) to a different brand that was 36 lbs. No performance loss and the tire weight is at a much larger circ. than a beadlock. Also, NEVER use run screws on a radial tire. Here is why... ![]() |
