Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 05-10-2017, 08:05 AM   #1
Todd Gross
Liked 54 Times in 24 Posts
Default Late Challenger Smart Door Glass Controllers
Has anyone experience with wiring the late model Challenger door glass with the smart controllers. The 09-11 Drag Paks have specific controllers that wired different from stock to control the electric windows. Those controllers are no longer available, as I've been told. I tried wiring the OEM controllers the same as the DP, but do not operate.
I have been sifting through schematics trying to piece it all together, but thought I'd ask if anyone has experience in this that may give me a short cut. Thanks
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 05-10-2017, 11:48 AM   #2
DonatoEng
Liked 8 Times in 5 Posts
Default Re: Late Challenger Smart Door Glass Controllers
I have new 08/09 Drag Pak window controllers. PM me John
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 06-20-2017, 06:41 PM   #3
Todd Gross
They are in and they work as intended. Thanks John!
Todd Gross
3323 FS/E,F
Old 06-21-2017, 09:15 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
One thing I have found on the DP window controls is they do not like 16v systems.
They will usually work when the car is not running , but when the car is running with a functioning alternator , voltage approaches 18-18.5 volts and the control module shuts down .
I fixed the problem on one of the DP's I work on by using a Runtz dropping resister that is made for dropping 12volts down to operate 6 volt gauges on cars that were converted to 12 v.
Tom Goldman is online now   Reply With Quote
Old 07-11-2018, 10:45 PM   #5
Stick cars rule
Stick cars rule's Avatar
I'm having the same problem with a 16 volt battery.i tried the runtz and voltage went from 16 to 7 and they don't like that either.any other ideas.
Scott justo.
2009018 lc22r
Stick cars rule is offline   Reply With Quote
Old 07-13-2018, 08:39 AM   #6
Tom Goldman
Scott, you can try this reducer ,it's made to reduce from 18 volts to 12 for electric golf cart radios. I've had good results with it.
Jeg's part number is 811-conv-00
