Old 02-21-2017, 04:26 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,390 Times in 506 Posts
Default Jerico Front Bearing
Does anyone know off hand if the Jerico front bearing, which measures 90mm outter, 40mm inner, and 23mm width, has SKF6308 NRJEM stamping on it? The one I pulled out of the spare trans I bought actually has SKF BBF-2308NRVBFS and needs to be replaced but Jerico assembly diagram calls for 6308NM - which seems very close to the SKF6308 NRJEM. I can get this fairly easily and quickly so it's the only reason I ask. Wondering if someone threw this other bearing in before selling.
'65 Mustang SS/L & L/SA
Old 02-21-2017, 05:24 PM   #2
MAURICE BLENDHEIM
Liked 287 Times in 88 Posts
Default Re: Jerico Front Bearing
Bobby…We've run up against this also. What we have learned is the Jobber Bearing has less Radial Load characteristics. The Jerico ball count is different internally (more). The Jerico Bearing is Proprietary and design specific, although the jobber is dimensionally correct it is inferior. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 02-21-2017, 07:31 PM   #3
Bobby Fazio
Ahh ok thanks.
