Old 10-14-2016, 12:57 PM   #1
parkdale
Smile SB Chev 355 or 406
building a street and strip engine and was wondering on the pros and cons on these two engines . I was told to stay away from the 400 . any comments ?
parkdale is offline   Reply With Quote
Old 10-14-2016, 01:48 PM   #2
larrylomascolo
Liked 77 Times in 31 Posts
Default Re: SB Chev 355 or 406
400 externally balanced,and do you see many out there,,i dont ,so that tells me enough ,,,,
Old 10-14-2016, 01:59 PM   #3
Dave1695
Liked 15 Times in 11 Posts
There is nothing wrong with the 400, with some minor upgrades that Chevy could have done. I ran one for years in my 67 Camaro, with small valve heads and cam from a 350. The car weight was 3100 and with 4.56 gears, ran 11 flat in ugly air and low 10.70's in good fall air.
Dave1695 is offline   Reply With Quote
Old 10-14-2016, 02:30 PM   #4
gd31
I'll add to the mix. How about a 383?
gd31 is offline   Reply With Quote
Old 10-14-2016, 03:01 PM   #5
TOSTO RACING
TOSTO RACING's Avatar
Liked 665 Times in 187 Posts
Have had a ton of 355's very reliable low maintenance motors. Roller cam Brodix track 1's and 13.5 to 1 comp 10.30's all day long in a 3400 pound camaro . Had a tunnel ram and splits on one in my 70 camaro back in the 90's ran. 9.80's at 3400 pounds ! Yiu can buy everything reasonable for one .
5664 GHI/SA
1985 CAMARO RED H/SA --- FOR SALE
1985 CAMARO BLUE I/SA --- SALE PENDING ON BLUE CAMARO!
TOSTO RACING is offline   Reply With Quote
Old 10-14-2016, 03:56 PM   #6
parkdale
i have some parts in stock for the 355 and the 406 but none for the 383 such as the stroker crank to fit the 350 block , i believe the rods are all 5.7
Old 10-14-2016, 11:07 PM   #7
dmir55
If you build a 383, you must cut the mains, of the 400 crank, to 350 size. Then you use standard pin height 350 pistons with a 400 rod. Good torque engine for the money. The 350 block seems to have better head gasket sealing. But nothing beats cubic inches.
dmir55 is offline   Reply With Quote
Old 10-17-2016, 02:47 PM   #8
Eman
Liked 133 Times in 76 Posts
Street,strip, bracket build a 350. There is no engine better for the buck, with incredible durability. If you want to build a 400 buy an aftermarket block now...or later when you waste a lot of time and money.
Old 10-17-2016, 06:16 PM   #9
carl hinkson
Liked 18 Times in 10 Posts
X10000000000000 I have seen a lot of guys spend good money on bad when it comes to OEM 400 blocks !!!
carl hinkson is offline   Reply With Quote
Old 10-17-2016, 06:31 PM   #10
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Build a 383....best bang for the buck in a street engine.
Stock 350 block...none of the 400 block problems...
I built lots of them....and with all the piles of inexpensive rotating assemblies out there now it's a no brainer and easy to do. You don't have to use a Stock GM 400 crank or the short GM 400 rods...
Only minor issue is rod to block and cam clearance and it's not much of a problem with any stroker type h beam rod.....
Stroker type rods usually clear a small cam with no problems.....
Easy to check during a preassembly...Only 2 pair of rods ever get close to the cam lobes anyway...
A decent stock block with little or no core shift just needs a little grinding at the bottom of the cylinders for the added stroke..
The cam to rod clearance is real easy to check.
I used strips of cardboard, or clay and a mirror....
A 383 has great torque and a perfect street strip engine...
400 blocks are nothing but problems...
Rich Biebel
S/C 1479
Stock 147R
