Old 05-24-2016, 10:20 PM   #1
Camarob859
Liked 8 Times in 3 Posts
Default Crankcase Pressure
Whats the best way to get rid of crankcase pressure with out a pan evac system for a small block stocker??
Camarob859 is offline   Reply With Quote
Old 05-24-2016, 11:09 PM   #2
mike britt
Liked 66 Times in 31 Posts
Default Re: Crankcase Pressure
Go get you an electric air injection pump off a toyota or gm and build a scavenge tank with a breather. Cheap and easy and fairly effective.
mike britt is offline   Reply With Quote
Old 05-25-2016, 07:10 AM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
My low buck solution and legal...
Rich Taylor
I/SA - 321
Old 05-26-2016, 12:29 PM   #4
V M Kauffman
The better the engine is sealed up the less Blowby you will have which equals less Crankcase Pressure you will have. If the engine is a wet sump you can measure the Blowby with a good Blowby meter. Low leak down readings do not equal low Blowby.anything over 2cfm is too much.
V M Kauffman is offline   Reply With Quote
Old 05-27-2016, 09:14 AM   #5
Glenn Briglio
Glenn Briglio's Avatar
Liked 978 Times in 313 Posts
What does this do?
Old 05-27-2016, 11:35 AM   #6
HandOverFist
Originally Posted by Glenn Briglio View Post
What does this do?
Just a simple path for pressure to escape.
Rich Taylor
I/SA - 321
Old 05-27-2016, 11:58 AM   #7
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
If you have the valve cover connected to the fuel pump block off I don't think you're doing anything. They see the same pressure. I use manifold vacuum through the base of the carb and run a vacuum gauge to measure pan vacuum. It's not great but I do pull about 5 inches at the starting line. That's with both crank seals in the correct way.
Ron Gusack is offline   Reply With Quote
Old 07-11-2016, 08:38 AM   #8
joespanova
Liked 13 Times in 11 Posts
Apparently you can't run a Dart block in stock.......because this would be pointless if you could.
The Dart block vents the crankcase through "slots" in the lifter galley like the big blocks do.
Old 07-11-2016, 09:17 AM   #9
HandOverFist
Joe - That would be assuming one would want/allow the oil to drain back directly over the crankshaft.
Rich Taylor
I/SA - 321
Old 07-11-2016, 09:34 AM   #10
joespanova
You'd think Maskin and gang would be well aware of that.....myself . I want the oil to get back to the sump as quickly as possible.
I'll manage windage some other way........
