Old 05-04-2016, 09:25 AM   #1
jwdsg2101
Default powerglide
In a powerglide if the stater support spins will it still produce enough line pressure to make a person think the pump is good to go? On the starting line motor won't go past 4000. Had my converter cut open but found nothing wrong. My converter man says I have a problem somewhere else.
jwdsg2101 is offline   Reply With Quote
Old 05-04-2016, 01:24 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 849 Times in 234 Posts
Default Re: powerglide
The transmission will still function , The tube has no bearing on the pump pressure , but with the converter feed restricted the stall will be off and trans temp will skyrocket due to the cooling circuit being blocked .
It should be easy to see the hole alignment of the stator tube when you disassemble the pump.
The tube ,stock or replacement should always be pinned with a set screw , but even that is not fool proof .
Old 05-04-2016, 01:52 PM   #3
jwdsg2101
Thanks for the reply. The stater was pinned with a set screw and since the trans had 210 psi idling in low gear I figured it had to be the converter. Will check to see if the pin is still in place.
