Old 03-07-2016, 07:50 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Windage tray
Is the Milodon Diamond Stripper a good choice for a BBC windage tray?
Should it be mounted close, like 1/4", to the crank?
I run a 7 quart pan with 6 quarts in it but haven't used a tray since 2009. I also use a scraper even though I've been told they are a waste of time. I had already made it so it became one of those "It can't hurt" items.
Ron Gusack is offline   Reply With Quote
Old 03-09-2016, 10:28 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: Windage tray
I didn't have good results when i tried diamond stripper tray in SBC
Mike Taylor 3601
Old 03-09-2016, 01:00 PM   #3
Ron Gusack
Ron Gusack's Avatar
Thanks Mike. I've read some positive things about the louvered trays. I went from a screen tray to no tray and didn't notice any difference at all.
Old 03-11-2016, 02:12 PM   #4
joespanova
Liked 13 Times in 11 Posts
Mike Taylor 3601
Whaddya mean , you "didn't have good results".
Did you dyno back to back between a tray and diamond stripper.........or make track runs and determine any variation in performance was solely due to a different tray / screen?
Old 03-11-2016, 05:01 PM   #5
Ed Wright
Ed Wright's Avatar
I have been told by two very sharp, well known, engine builders to not use a tray. "Leave it out" they said, and that they always just pitch them. That getting the oil back in the pan faster is more important. I pulled the tray, did not slow down one bit. I have not used one since. That was in 2010. I think maybe you are looking in the wrong place for hp. jmho
Ed Wright 4156 SS/JA
Old 03-11-2016, 05:19 PM   #6
Signman
Liked 269 Times in 99 Posts
What are you doing to keep oil from getting sucked up out of the sump?
Are you using a kickout pan?
Old 03-11-2016, 06:30 PM   #7
Ed Wright
Ed Wright's Avatar
One man that told me that has tested big blocks on his dyno with a clear plastic pan they built, so they could actually see what was going on in there. He said it was hard to see, lots in the air. They do not use kick outs. Most SS cars seem to use full length sumps. I just have a Moroso with kick outs, but I'm cheap.
He said about nothing sucking oil up out of the pan. This is the first I time I've heard that one.
Old 03-11-2016, 06:50 PM   #8
V M Kauffman
You did the right thing with the scraper, it take time to fab a good one. There is a company in Fla that makes very good ones. As far as kick outs they help on passenger side. Depth put the deepest biggest box you can. Often over look is the shape of the pick ups. Moroso has a small box style pick up that is very good, biggest thing about your pick up is to make sure it is not just sucking a hole in the pump and oil is not getting into pump.
V M Kauffman is offline   Reply With Quote
Old 03-11-2016, 07:22 PM   #9
Lee Valentine
Liked 319 Times in 68 Posts
What Ed said, haven't used a windage tray in years. Was told by some very good engine builder's oil bounces off them right back to the crank.
Lee Valentine 1661 STK
Old 03-11-2016, 07:29 PM   #10
PETE PEERY
Liked 35 Times in 12 Posts
The rear cylinders move a lot of air on their way down so i think it is very important to have some type of baffle obstructing this. You can weld it to pickup tube or attach to pan but just do not want the air blast to have direct path to pickup area. just my opinion.
PETE PEERY is offline   Reply With Quote
