Old 02-10-2016, 07:47 PM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Default Ring thickness
On a stocker with 5/64 rings ,are there spacers available to run 1/16 or are the dykes still what I should run .? Do I need to back cut 1/16 rings ?
Mike Savelle is offline   Reply With Quote
Old 02-10-2016, 09:00 PM   #2
Liked 1,952 Times in 439 Posts
Default Re: Ring thickness
Call Keith Jones at Total Seal, you want the "Advantage" ring package. If you have already bought pistons, you'll need exact ring groove measurements, which you can get from your piston supplier if you have your invoice and/or job number. If you have not bought pistons, have Keith give you the ring groove dimensions he wants you to run.
Old 02-10-2016, 11:21 PM   #3
carl hinkson
Liked 18 Times in 10 Posts
Go thinner then 1/16 if you can !! Napier second ring and ultra low oil tension ring.
carl hinkson is offline   Reply With Quote
Old 02-11-2016, 03:14 AM   #4
GTX JOHN
We run faster and less issues with Race Rings by Tri City Performance.
We have had several problems with making the Total Seal ring work
John Irving
741 Stock
741 Super Stock
Old 02-11-2016, 08:55 AM   #5
carl hinkson
What problems have you had with Total Seal rings I have been using there products for years with zero problems.
I guess it boils down to if know what your doing it makes a big difference.
Old 02-11-2016, 09:51 AM   #6
Liked 11,032 Times in 2,267 Posts
Tri City and Total Seal are very good rings. The top steel ring is sometimes a little slow to seal up.
Old 02-11-2016, 10:22 AM   #7
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
I had good results with Tri City and using spacer with dykes.
Mike Taylor 3601
