Old 10-06-2015, 01:36 PM   #1
Shaun Quill
Liked 105 Times in 26 Posts
Default Synthetic Oil and Solid Lifters
I want to start running Synthetic oil, but I was told a solid cam and lifters may not live,but you can possibly add Zinc to it. I've run solid lifters with synthetic oil in the past with zero problems, does anyone know for sure?
Old 10-06-2015, 01:39 PM   #2
Shaun Quill
Default Re: Synthetic Oil and Solid Lifters
I meant to put this in Tech I'm sorry
Old 10-06-2015, 04:22 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Synthetic Oil and Solid Lifters
There shouldn't be a difference between hydraulic & solids. If there is a problem with the metallurgy, spring pressures, oil, break-in procedure, etc., you'll have problems with the cam & lifters with either one. I've used Amsoil synthetics in my hydraulic lifter engines before I switched to the Schubeck/Smith composite lifters with no issues. There are several synthetics that have plenty of zinc in them and it makes sence to find a brand that has a formula that includes enough zinc rather than playing "chemist".
http://www.amsoil.com/techservicesbu...t%20Tappet.pdf
LOCOMOTION Racing
Old 10-06-2015, 04:46 PM   #4
Shaun Quill
That's what I needed to hear.Thank You Sir.
