Building a new shop for the race cars, fab work, atv's, kids junk, truck and trailer, etc.
Would like some recommendations on what to do to the floor. Dallas, TX, so very hot and not too cold. Will not be heated or AC. Do not want epoxy. I am thinking about a densifier sealer combo. Not looking for gloss. Just want to protect the concrete and make it easier to clean up. Suggestions on what and what company to use? thanks, Ken Stock 412 |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
Liked 320 Times in 102 Posts
Hi,
Just putting the finishing touches on a 40 x 60 shop........ After my doors arrive I will also be looking for a floor covering...... I got some input from my concrete contractor on sealers and I am also in information gathering mode..... It will be a sealer type for sure, but I don't know what kind or brand yet?????? Bob
Liked 18 Times in 11 Posts
I am finishing up 30 x 60 shop and did some research on the coatings and went with U Coat it system. I know the OP didn't want epoxy however this is the direction I went. I talked with Armor Coat and their system was really pricey and they had poor follow through.
The key is in the preparation and keeping moisture from weeping up. When we poured the concrete, prior we put down moisture barrier between the ground and the base. With a "fresh pour" you have a far better shot with success of adhesion. Make sure to wash the concrete with acid twice to get concrete to open up and get a tight bound. Most "non-epoxy" finishes with not hold up to tires sitting on the finish for long periods as the tires will breakdown the finish and pull up the coating. Just passing on what I learned.
Eric Voigt 7425 STK |
For what this is worth, my U-Coat-it floor is two years old and tires will still leave brown stains that do not come up. Not just the tires on my drag car, daughters Sea Doo, and my DD's will leave tire marks as well.
I do like my floor but I am disappointed in some of the durability issues that have come up. Scratches VERY easy, and for some reason the wheels on my shop chairs mark the floor and it's a dog to clean up. Just my 2 cents. |
Liked 126 Times in 61 Posts
Sherman Williams has some good products. A concrete stain. Its a available in tints or just clear. It is solvent based. I rolled it on, it gets tacky very quickly. Gas, oil etc. doesn't effect it even after days. Tires won't pull it up. Makes cleaning up so much nicer. MY garage is 30' x 30'. New concrete floor just swept it clean before. MAchine floated floor that was very smooth.
Liked 20 Times in 15 Posts
For your shop use the silver foiled bubble wrap insulation over the stone and before the rebar goes in. Keeps the floor cool/warm and is an excellent vapor barrier. Don't forget to add a thicker pad area if you will be adding a lift in the future. As for a surface finish, this is a pore sealer, 50/50 mineral spirits and polyurethane 1 months after the concrete cures(rinse and maybe some vinegar.. Unlike modern sealer that are acrylic and don't penetrate much.They are a top coating that wears and not solvent(brake cleaner) friendly. Being deep in the pores, the poly doesn't let oil seep in. You never have to re do it.
