Old 07-29-2015, 11:33 PM   #1
THE LEGEND
Default G body manual brake master cylinder
Looking for a kit. Wanting to remove the booster from the Monte. Where can I find a kit with plate, push rod, and master cylinder, that's easy to install
THE LEGEND is offline   Reply With Quote
Old 07-30-2015, 07:32 AM   #2
Billy Nees
Liked 7,730 Times in 1,739 Posts
Default Re: G body manual brake master cylinder
Look at the "Under the Index for Under a Grand" thread. Quick and easy AND safe. BTW, I never even took the orig. MC off of the car.
Billy Nees 1188 STK, SS
Old 08-01-2015, 09:50 AM   #3
Dave Cook
Dave Cook's Avatar
I took a m/c off an '81 Chevy truck with manual brakes (aluminum / plastic) with the pushrod and pushrod retainer, had to fab up the mount plate and customize the rod length, no differential valve at all, works well.
Whatever you do, don't forget to positively retain the m/c push rod.
About $40 for a new m/c once I fitted it all up.
Dave Cook is offline   Reply With Quote
Old 08-01-2015, 02:14 PM   #4
FED 387
Liked 332 Times in 180 Posts
Go to Advance Auto Parts --- part number 10-1737 1978-1987-G body MANUAL BRAKES master cylinder--- $26.49---FED 387
Old 08-01-2015, 02:30 PM   #5
Liked 5,121 Times in 1,952 Posts
Couldn't be mush easier than this.
I did one like this back in about 1985. Never had a problem.
You could drill the hole in the piston deeper and use a longer rod, if it makes you feel better, but not necessary if you use a retainer and WELD it all together. No threaded adjusters
I don't believe you will need to buy a manual m/c.
Made it even easier:
http://classracer.com/classforum/sho...t=44903&page=3
