Old 07-27-2015, 12:17 PM   #1
Tgreen3724
Default A/F Ratio
454/425 Super Stock BBC running a two step button and footbraking. AF ratio runs about 16:1 on two step then dives all the way to 11:1 immediately after release of the two step button. Then two seconds into the run AF curve flattens out and remains in the 12.5 to 12.7 ratio range. Is this normal for the AF ratio to dive from 16 to 11 after the two step is no longer activated? Ratios remain under 12 for two seconds of run then flatten in the upper 12 range for remainder of pass. Is this normal? Thoughts?
Tgreen3724 is offline   Reply With Quote
Old 07-27-2015, 06:13 PM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 747 Times in 136 Posts
Default Re: A/F Ratio
Yes, Mine does exactly what you describe, however I'm not seeing nearly that long for mine to get back above 12... p.m. me if you like.
Kevin
Old 07-27-2015, 06:29 PM   #3
Bob Shaw
Liked 316 Times in 61 Posts
Have you tried checking the A/F ratio without using the 2 step? Mine keeps getting richer the longer I am on the 2 step.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 07-27-2015, 06:43 PM   #4
Tim Lisson
If you have the sensor towards the end of the collector, you will not read an accurate reading on the two-step, and it will always reflect a lean signal.
The fuel is puddling in the intake and after launch it should show rich due to the blast of fuel. Sounds like you could pull a little fuel out of it but then again, each combo likes something different.
Tim Lisson is offline   Reply With Quote
Old 07-27-2015, 09:10 PM   #5
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
The AF ratio is calculated by input from the O2 sensor. Wide or narrow it's still an O2 sensor. The O2 is seeing lean while on the limiter because the engine is missing & oxygen that normally gets used up in combustion, isn't. It would be interesting to see the curve on a run without the two-step.
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 07-30-2015, 08:20 PM   #6
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
One of the key elements on this is where the O2 bung is located. In the collector, carb car, guaranteed crazy reading (on 2-step) - in a primary tube - it might be ok or will straighten out much more quickly. The reason for this the back-pulses of clear air coming into the collector at lower RPM's.
Big cube bracket cars can get away with it in the collector. Stock & SS - put it in the primary.
Also, EFI cars seem to have more stable O2 readings on the 2-step.
Here is a log of a car showing pretty stable O2 readings bungs are in primary tubes. BUT it is an EFI car.
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
