Liked 99 Times in 60 Posts
Racers,
is anyone monitoring the cooler line outlet temp? [that is to say, the fluid temp as it exits the case] If so, tell me how you did the plumbing and did you learn anything useful? Thank You
Larry Woodfin 471W |
#2 | |
If you plan to do so, I recommend you use something similar to the Peterson Fluid Systems sender plumbing with a smaller size line. http://www.petersonfluidsys.com/plumb_inline.html |
Liked 240 Times in 112 Posts
I have a trans temp gauge in my car but the sender is in the pan. And I use a cooler as well. 200 - 250 is common on my car.
Dave Noll, EF/S ,?/SA 6526 |
Liked 239 Times in 114 Posts
You will be measuring the highest fluid temperature coming out of the transmission. Most production transmission run the outlet oil from the torque converter directly to the cooler.
Larry,
I did this years ago on my 10.90/bracket car. Used a oversize brass 3 way fitting, bushed it down for the #6 braided hose I was using in and out. Dont remember the exact size, but was big enough that the probe in the center fitting did not hurt flow any... I did this back before I was using synthetic fluid. Was setting up for .00x lights and trans temp/converter temp made a difference. Also impacted et's, but I used it more for my reaction time changes. After I went to synthetic fluid, temps did not move as much, and did not seem to be as critical. Just monitor pan temps now. But, also foot braking and not setting up for .oox's anymore either. Look forward to seeing you soon. Ken Stock 412 |
Ken, Thanks
We plan to test at Ennis July 25 and a date or two in August. Then the Lucas race in September at Thunder Road. be sure to look me up.
#7 | |
Sponsor
Liked 9 Times in 1 Post
To us cooler pressure is more important. It affects converter flash and coupling to a point. If you have two transmissions and one has 40 psi cooler pressure one has 80....the same converter will act different. There is a ton of adapter fittings though with 1/8th NPT holes and -6 to -6 etc http://www.summitracing.com/search/b...=npt%20fitting |
#8 | |
Liked 1,953 Times in 439 Posts
I know I went from another builder's setup, where they had bypassed the cooler in the case and the pump, to an unmodified case and pump, with a simple steel 5/16" line loop between the two cooler fittings, and saw over 400 less RPM for the same MPH, in a GM automatic with an 8" ATI converter in a Stock Eliminator car. But it did not seem to change the flash RPM, leaving off a two step set at 3200, the converter flashed to 5700 RPM regardless of whether the cooler was bypassed inside the transmission, or externally.
Alan Roehrich 212A G/S |
Typically the converter charge pressure is regulated, this is what goes into the converter. The outlet of the converter goes first through the cooler, then all of that is plumbed through the lube system (gears, and clutch plates). If changing the case and pump affected the restriction in the cooler loop, it could change the converter charge pressure which could change the efficiency , that might get you the 400 rpm. The problem is you are getting less lube to the gears and clutches, which means more transmission maintenance, might be a good trade off if the on track performance is improved.
#10 | |
