Old 07-11-2015, 08:36 PM   #1
Maverick
Liked 36 Times in 26 Posts
Default basic delay box
I am doing some research for a single function delay box that will delay the signal to trigger the launch. I don't need a throttle controller, or a SLE. Just a delay box that you can change the delay quickly, and I don't need bump up on bump down and no crossover function. I don't know how the signal for the trans brake works whether it is a high signal or a low signal. It would be nice if I could have the input and output, to be active hi or active low in or out, in other words selectable. This is of course not for a trans brake car. Just doing the research, and I really don't know if it will work in my application. SteveWilliams
Old 07-12-2015, 04:35 PM   #2
Maverick
Default Re: basic delay box
Calling biondo Monday
Old 09-03-2015, 10:01 PM   #3
gnicholson
Liked 4 Times in 3 Posts
I have a dedenbear rt6 you could try
gnicholson is offline   Reply With Quote
Old 09-08-2015, 04:03 PM   #4
Maverick
Thanks, but after talking with Biondo, the basic box won't work the way I want. The basic box takes a high to trigger a high out. All my stuff is low to trigger. Over the winter I will contemplate it some more
Old 09-08-2015, 06:47 PM   #5
voltdr
Liked 100 Times in 51 Posts
You can always use the high output of the delay box to trigger a relay and have the relay pass the low signal through it.
Dan
voltdr is offline   Reply With Quote
Old 09-15-2015, 05:00 PM   #6
gnicholson
I don't understand that. It will switch whatever you input into it like a relay
