Old 05-24-2015, 03:07 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default In search of
Unfortunately I guess I got a raw deal with my so called stocker that I traded for. After spending $3000 replacing the th350/2.52 with a th200/2.75 and installing what should be the correct converter, and trying 3 diff carbs ending with a fresh boburka carb and brand new M/T radials I can only manage a 7.80/12.33 at 50lbs light for G
85 Camaro 305/263 combo
I need to start from scratch with a new motor. So I need everything but right now it is on a budget
416 heads already done with or without valves and springs
055 intake already done
pistons, rods and crank
block
I will be removing the motor I have but the block has the outer starter bolt hole almost completely broke off and I am sure the rest of it is literally stock
Just pm me with whatever you have with price. Thanks
jamie2370 is offline   Reply With Quote
Old 05-28-2015, 02:39 PM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Default Re: In search of
Jamie, you have a PM
Robert Simpson is offline   Reply With Quote
