Old 04-17-2015, 11:21 PM   #1
HP HUNTER
Liked 373 Times in 129 Posts
Default Rotational Weight Question
Lets say you have C/SA 69 Camaro 375/396, If you ran a conventional 12 bolt with a steel spool non gun drilled axels and ran 10.50 with 1.36 60 foots, if you built a 12 bolt with 35 pounds less rotational weight and ceramic bearings, how much would you pick up?
Old 04-18-2015, 02:08 AM   #2
GTX JOHN
Default Re: Rotational Weight Question
I think if you picked up .01 in 60 that would be a lot.
John Irving
741 Stock
741 Super Stock
Old 04-18-2015, 07:10 AM   #3
Ed Wright
Ed Wright's Avatar
I put an aluminum spool and lightened gear set in mine, and found nothing. I don't waste my money there anymore.
Ed Wright 4156 SS/JA
Old 04-18-2015, 08:07 AM   #4
Tom Meyer
Liked 354 Times in 120 Posts
My thoughts are, you could pick up more by having your rear end square in the car and all moving parts on it move smoothly with no binding. The right lube and how much is also important along with having the gears properly set up. I also don't think you could get 35# out of a 12 bolt and if you could all that it would help would be sprung unsprung weight. Tom
Tom Meyer 5240 SS Stock ???
Old 04-18-2015, 09:26 AM   #5
HP HUNTER
What lube do you run?
Old 04-18-2015, 09:54 AM   #6
tj310
I remember a saying that was attributed to Colin Chapman
A gram of reciprocating weight is worth an ounce of rotating weight
an ounce of rotating weight is worth a pound of chassis weight
Take that with a grain of salt. ---Trevor
Old 04-18-2015, 02:36 PM   #7
FED 387
Liked 336 Times in 183 Posts
I was always told that rotational weight is equal to 4 times the actual weight---- that means that for every pound the effective weight that the engine is trying to overcome would be 4 pounds--- now this may depend on how great the diameter of the object is--- in other words if you have an item that is 2 inches in diameter the rotational weight difference will not be as significant as say an item that is 12 inches in diameter where it should be greater--FED 387
Old 04-18-2015, 09:30 AM   #8
HP HUNTER
Do you think a foot brake combination might have different results? I appreciate all opinions, just trying to learn.
Old 04-18-2015, 07:23 PM   #9
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
They may not have the same effect. Also, is the rotational weight wheels or axles? Brakes or spool? Rotational weight isn't all the same. All the weight can be quantified if you know the moment of inertia.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 04-18-2015, 07:28 PM   #10
ron mattson
Liked 69 Times in 32 Posts
Very good replies and in my experience
there is more between the fenders than
You will ever find in the diff!! My.02$$
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
