Old 04-11-2015, 11:13 AM   #1
Lyn Smith
Liked 1,002 Times in 203 Posts
Default q jet ,4 jet jets
Can you use quadrajet jets in a rochester 4 jet carb?Been a while since i worked on one. thanks
Lyn Smith is online now   Reply With Quote
Old 04-11-2015, 12:27 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: q jet ,4 jet jets
Lyn,
I do not know the answer about jet size.
What I do have is one mid 60's Rochester 4 jet. If there is a desirable style I will check what I have. If you can use it pay the shipping.
Larry Woodfin 471W
Old 04-11-2015, 02:33 PM   #3
Tom Meyer
Liked 354 Times in 120 Posts
Lynn the jets work but if you look at them the 4 jet is flat in the center the q jet is tapered or other way around, so they flow different. If you change from one to the other you may not be changing anything at all. I know that you can get them for a Holley but does anybody know where you can get jets flowed. Tom
Tom Meyer 5240 SS Stock ???
Old 04-11-2015, 11:21 PM   #4
Lyn, The Q jets are tapered to accommodate the primary rods
Otherwise interchangeable...1/4 28 thread
Old 04-12-2015, 10:37 AM   #5
Lyn Smith
Thanks for the info and help.
Old 04-13-2015, 08:30 AM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Not all 4gc jets are flat across the inside. There were three different designs over the years - one was flat, one had a small 45 degree chamfer at the top and the third had a large 45 degree taper cut that extended half the distance of the jet body. All had different flow characteristics so it is imperative when tuning that the same style jets is used when changes are made. Qjet jets will fit, but you may have to experiment with sizes to get the correct fuel-air mix if you have references from one of the 4gc jet styles.
