Old 03-27-2015, 03:31 PM   #1
gbur
Default 2001 Camaro driveshaft
Anyone had issues wiih vibration above 5000 rpm in 3rd, seemingly shaft is too short ?
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 03-27-2015, 03:54 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: 2001 Camaro driveshaft
Yes there are several GM bulletins on it. And the problem only gets worse if you put a numerically higher than factory rear gear ratio in it. I'm assuming here that you are talking about a GM drive shaft. In my street cars I put 1LE driveshafts in them. I have them rebalanced as well. They don't have the heavy trans Yoke with the balancer on them which makes them easy to spot in a salvage yard if you are looking. Can find them on Ebay too but usually priced like Gold there. . On both my racecars I put aftermarket shafts in them.
Old 03-27-2015, 05:47 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The 1LE driveshaft is aluminum, which dampens out those vibrations. It was a service fix for awhile. Watch out though, if you drop the clutch with high traction tires, it may twist up like a pretzel !
Old 03-27-2015, 05:50 PM   #4
gbur
4L60E here
Old 03-27-2015, 11:17 PM   #5
ss3011
ss3011's Avatar
I think the 4L60, and the manual trans, uses the same driveshaft.
Old 03-28-2015, 01:03 AM   #6
gbur
that is what all references say
