Old 03-19-2015, 08:06 PM   #1
fastmachone
Default Which rear end would I be better off with?
which rear end would I be better off with, an 8 3/4 or a Dana 60?
fastmachone is offline   Reply With Quote
Old 03-19-2015, 08:28 PM   #2
Bill Baer
Default Re: Which rear end would I be better off with?
Well that depends if weight is no problem, the Dana 60 is more durable but it's pretty heavy and it's unsprung weight which means the type of suspension you run can be affected.
The 8-3/4 is lighter but not as durable and probably cheaper.
I guess it boils down to this, big tires, manual trans, heavy car, big motor
consider the Dana.(I.e super stock, super gas/ comp, top sportsman)
Small tires, auto trans, and or light car , small block use the 8-3/4 (I.e a stocker or bracket car).
That's my two cents worth (Mopar guys opinion's will vary)!
Old 03-19-2015, 09:41 PM   #3
GTX JOHN
Liked 2,484 Times in 697 Posts
How fast and how heavy a car are you
considering?
John Irving
741 Stock
741 Super Stock
Old 03-20-2015, 04:17 AM   #4
Rod Greene
Liked 242 Times in 81 Posts
Thumbs up Re: Which rear end would I be better off with?
Dana 60 all the way. The dana I had in my car was only 20lbs heavier than the 8 3/4. It is bullet proof and takes less HP to rotate. It is a no brainer. If you run an auto if you break the rearend it takes the tranny with it. Just one more reason for Dana.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 03-20-2015, 07:30 AM   #5
Liked 10,704 Times in 2,229 Posts
Dana 60 is faster than 8 3/4 I back to back them at Indy one year. They last longer than 8 3/4, bought mine in 1991 and still using all the same parts.
Old 03-20-2015, 09:55 PM   #6
fastmachone
The car is a 1976 Volarie, 360 4 BBL Stocker. I'm thinking 4500 stall and 5.13 gears.
