Liked 985 Times in 314 Posts
What manufacturer sells the thinnest head gasket for a bb chevy 396?
Liked 1,953 Times in 439 Posts
If you can find them anywhere, GM made one around 0.028". I think the one Mr. Gasket makes is thicker. The only other choice is either dead soft copper from some place such as Hussey or SCE, or a Cometic.
Alan Roehrich 212A G/S |
Liked 485 Times in 160 Posts
Old # used to be 1131 MR G I recall. Bore was 4.37 though.
Liked 10 Times in 7 Posts
Glenn
I think I still have a set of GM ( I think .015 ) Steel gaskets. I will look in the morning and get the part # off of them. |
Liked 287 Times in 88 Posts
Glenn… I've been using the MR.GASKET 1131G they are .018 -.020 thick and coated. They are 4.370 Bore and economical. Hope this helps. MB.
Liked 336 Times in 183 Posts
GM # 14015351----steel shim .022 thickness -----4.250 bore----- STEEL HEADS ONLY------seal with alum spray paint-----re-torque after first heat cycle-- or look for LS-6 OEM gaskets ---also check quench area clearance very important!!!! FED 387
Liked 280 Times in 139 Posts
GM# 3993890 would be the one you would want,.022 thick,small bore(4.125).Or old stock Victor equiv..The problem is they are hard to find,the Mr.G, Rocket, etc are all big bore generic BB. gsa612
lGM 3993890 look on ebay.com and ebay.ca they are on there all the time $20-50 a pair
