Old 02-15-2015, 05:48 PM   #1
russellauto1
Liked 35 Times in 6 Posts
Default Braille Batteries
Any one using there light weight in a EFI car with alternator? Do the hold up? Was thinking of losing 20#s by switching from a full size to a smaller braille. Thanks
russellauto1 is offline   Reply With Quote
Old 02-15-2015, 06:00 PM   #2
Rsmith38
Liked 28 Times in 15 Posts
Default Re: Braille Batteries
There was a thread last year about lightweight batteries. I used an 11#
Braille in my Jeep 4.0 and it was not enough! After using a 15# Deka PowerSport I ended up with a 21# Deka Powersport (Walmart sells them under their name). East Penn battery is the maker of many different name batteries. I suggest the 21 lb unit on anything that has FI, elect fan and waterpump, MSD ign. I also charge between rounds.
Rsmith38 is offline   Reply With Quote
Old 02-15-2015, 06:03 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Not efi Russell, but I use one (B3121) in the Camaro. I've only had it in the car for a year, but it seems to be fine. Be advised the Braille charger will not operate with many generators.
Rich Taylor
I/SA - 321
Old 02-18-2015, 08:08 AM   #4
Liked 11,032 Times in 2,267 Posts
We run two 11.5# in the Cuda and they last about three years. They work very well.
Old 02-18-2015, 10:45 PM   #5
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
We tried a ProLite Lithium battery a year ago in the COPO Super Stocker. 120 amp alternator regulated to 18 V max as we where told by ProLite. Charged it to green one night before loading, pulled out the next day and it was stone dead. Needed a $350 rebuild, used it for 3 outings and had it in the car for maybe 2 months. Pretty pissed off since we asked a lot of questions about it before buying. Took it out and sold it. Maybe it was a bad one, maybe not, but either way it ended up costing me a lot of time and money.
ATI Racing
ATI Performance Products is offline   Reply With Quote
Old 02-19-2015, 09:15 AM   #6
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
I'm on my third yr. with one in a EFI mustang, stock alternator. Works like a champ. I put it on a trickle charger at home every once in a while. For running the electric radiator fan between rounds I use a separate deep cycle battery so I don't need to charge the braille battery between rounds. It's in a pure stock car so it has oem water pump.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 02-23-2015, 03:52 PM   #7
Matt Welker
Liked 77 Times in 15 Posts
You will like the Braille Battery, standard or lithium. Email me and I can give you a direct contact at Braille to discuss your needs and take your order.
Matt Welker
matt@welkerlawfirm.com
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is offline   Reply With Quote
Old 02-23-2015, 04:07 PM   #8
HandOverFist
Brian - What model # are you using in your Mustang?
Rich Taylor
I/SA - 321
Old 04-13-2015, 11:42 AM   #9
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
Check out our Powerlite batteries. We offer different capacities to fit your application with weights from 5 to 10 lbs. Also offer protection circuits to prevent over discharging that can prevent damage. These lithium batteries can live 5 times longer then other battery technologies, are extremely light weight and can charge many times faster.
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
Old 06-28-2015, 12:56 AM   #10
HandOverFist
Regarding my previous post about the Braille charger not working with some generators...this proved to be false. I found my Yamaha 2000 generator has a switch/governor which when selected only ramps up according to load. This setting was not enough to excite the Braille charger. By turning off this feature of the generator the charger now activates...the Braille 10 amp charger tops off my batteries quicker than any other I have tried. My apologies for the previous misinformation.
Rich Taylor
I/SA - 321
