Old 01-20-2015, 11:22 PM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default 283 pistons
Does anyone make a stock replacement shelf flat top 283 piston larger than .060 over? This would be for a restoration project and the block is at .060 now. Early 721 nova block.
Jim Hawkins is offline   Reply With Quote
Old 01-21-2015, 12:08 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: 283 pistons
at one time Federal Mogul made them--- not sure if they are still available--FED 387
Old 01-21-2015, 10:02 AM   #3
my69396
Liked 46 Times in 20 Posts
Check with Egge Machine. They even have 4in 283 pistons for a old school 301.
my69396 is offline   Reply With Quote
Old 01-21-2015, 10:47 AM   #4
BillK
Liked 30 Times in 17 Posts
Jim,
Looks like Silvolite has them in .080, part number 1412.
Hope this helps,
Bill Koustenis
BillK is offline   Reply With Quote
Old 01-21-2015, 03:14 PM   #5
Jim Hawkins
Thanks for the info.
Old 01-21-2015, 07:58 PM   #6
Tom Meyer
Liked 354 Times in 120 Posts
That block will go to 4 in without any problems, save the hassle with getting the big overbore stuff. Put a 327 SJ crank and stock 4 in bore piston and have fun. Most of 721 blocks were good pieces and were built to go to the 327 in the 65 cars. Tom
Tom Meyer 5240 SS Stock ???
Old 01-21-2015, 11:33 PM   #7
Jim Hawkins
Tom, that is what I intended to do with this block. I am selling this block and the guy who needs it for his 64 nova is afraid it will run hot at 4.00. I told him that it has been done before but it scares him. Oh well go figure.
BTW I also have a 3862194 block from a 67 nova, are these as thick as the 721 blocks? Never had it sonic tested.
Old 01-22-2015, 07:37 AM   #8
james schaechter
The 194 is a good block for a 283 street car. It is as thick as any regular 283 block. Probably a better choice for a 283 street car. The 721 block is an awesome 283 race block! It would be a shame to waste it on a street car! Gm made these same blocks into 327s for Chevy 2s so overheating would not be due to thin walls.
James Schaechter 3163 STK
Old 01-22-2015, 11:33 PM   #9
Jim Hawkins
Is it worth the cost or necessary to put 4 bolt caps or fill the 721 block for a race car motor? This block I have was from a old modified motor. 3.935x3.00 292 cubes. Not filled and stock caps.
Old 01-23-2015, 06:41 AM   #10
james schaechter
I guess it depends upon the power and rpm. We put studs on ours, but kept the two bolt caps. Never had issues and went 8000 plus in our stocker.
