Old 09-08-2014, 07:03 AM   #1
joespanova
Liked 13 Times in 11 Posts
Default EMI / RFI and setting timing = problems
Since I switched from an older MSD ignition ( analog 6AL and blaster coil ) from way back in the day to a newer Digital 6AL and E-core style 8252 coil I have EMI problems to the point I can't get a steady , make that even anywhere NEAR readable observation on the balancer. I'm getting plenty of interference. I've grounded everything , used "Spark guard" , moved the mag pick up trigger wires.
Anyone else able to share some things you've done to stop it?
Magnacor offers wires they say stops it..........dunno.
http://www.magnecor.com/magnecor1/main.htm
read down to EMI suppression.....interesting.
Old 09-08-2014, 09:00 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: EMI / RFI and setting timing = problems
There are 2 things to consider here, first have you tried using a different timing lite, I've used some that just will not work on an MSD ignition system. Second Where do you believe your "noise" is coming from? Every wire that has electrical current running thru it CAN emit noise, the trick it seems is in minimizing it. Before you spend a bunch of time and possibly money, borrow another timing lite and see if you have the same issue, a lot of lites' pickups are extremely sensitive to EMI, most modern wire sets are fairly good at suppressing noise. P.S. most dial back lites seem to be problematic when used on MSD ignition systems especially the digital ones.
Joe Buchanan SS/BX 3117
Old 09-08-2014, 09:28 AM   #3
joespanova
I have 4 lights......Craftsman , Flaming River style ( self powered ) and a couple Actron lights.......they HAVE worked , now I'm getting so much noise and have no clue as to why........
I'm going to swap a set of cheap suppression wires and see if there is a diff from the MSD wires.................maybe that'll make it worse?
Old 09-08-2014, 10:38 AM   #4
buzzinhalfdozen
Where are you connecting the inductive clamp? Have you tried moving it near the plug end? Is the lite erratic or the timing erratic, or can't you tell? Does the engine run normally? I didn't see where you stated what wires you have or how old they are, older (with much use) sets can indeed start to leak. I've saw sets that when you turn the lites out in the shop and it's dark look like a fire works show. Also just a thought, make sure your power and ground wires to your lite as well as the pick up wire are not laying on or near any ignition wire. When wires start to leak a simple test with a spray bottle of water can locate the issue, with the engine running I'll lightly mist the wires with water and see if engine stumbles or I can hear arcing.
Old 09-08-2014, 11:01 AM   #5
joespanova
The engine is crank triggered...so its close..........just need to finalize the timing....it starts easily and sounds healthy. The wires are new MSD 8.5s.
Old 09-08-2014, 11:24 AM   #6
buzzinhalfdozen
OK, well I've never used any MSD wire but let's assume they are NOT the cause of the interference. Do you have an alternator, electric fan, electric water pump, and are any of them on when you're trying to time the engine?Also does the timing lite have what looks like a flash every other revolution or is it pretty much on? Have you tried indexing the rotor, do you have a steady lite doing that? Maybe try merely trying to get a steady strobe by moving cables around and see if you can get that first. You say it's a crank trigger set up, are there any wires near your crank trigger wiring? Sorry for all the questions but it's harder to find the issue without actually seeing the set up first hand. One other thing you could try if you have one...put a spark checker on one of your plug wires and see if you're getting normal spark or extra spark events.
