Old 08-21-2014, 11:09 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question 1957 chevy in stock
Can you run a 57 chevy in stock now?
What class will it fit with what engine combos?
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 08-22-2014, 09:02 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: 1957 chevy in stock
Yes you can run 57,not sure on combo's should be in guide,I know probaly 265,283,235 six
don't know what combo's of these engines but know they came with them
Mike Taylor 3601
Old 08-22-2014, 10:37 AM   #3
Dragsinger
Liked 99 Times in 60 Posts
I understand it is not your original question, my thought, sure would make a good GT or Crate Motor project.
To answer your original question, to my knowledge a 57 is acceptable in stock with any of the original factory engine combinations. [as posted above]
Also, how cool with it be to run the 283 with 2 carbs. [a 283 - 283 horse was available in 57 with four speed. it used a low profile 2 x 4 intake]
Larry Woodfin 471W
Old 08-22-2014, 11:02 AM   #4
ss wannabee
Liked 7 Times in 7 Posts
Larry...the 283/283hp engine was with Rochester Fuel Injection and Duntov 097 cam....
There were 2-2x4 carb combos...270hp with the above mentioned 097 cam...and
245hp with a regular hydraulic cam...Cylinder heads and cc's may differ as well so
one should check the latest NHRA engine specs to see what's permitted....
Was the 250hp FI engine (with regular hyd cam) available in '57 or did it come later?
ss wannabee is offline   Reply With Quote
Old 08-22-2014, 01:02 PM   #5
Dragsinger
yep, my "old timers" is showing
also, the correct carbs and manifold while could be found, whew, talk about expensive.
Larry Woodfin 471W
Old 08-22-2014, 02:16 PM   #6
The 283 4bbl can use the 459 327/250 intake now, plus a 3 speed trans..Not a bad P/SA
car.
The 283 / 245 2x4 deal would be more expensive to build. It would probably be somewhat faster , but I doubt it would cover the half second index loss.
