Old 08-17-2014, 07:24 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default super stock "engine mounted" fuel pump
What are some engine mounted pumps that give excellent service and performance? Also, what return regulator?
Thank You
Larry Woodfin 471W
Old 08-17-2014, 10:50 AM   #2
Liked 1,822 Times in 413 Posts
Default Re: super stock "engine mounted" fuel pump
Why? Not sure what you're trying to do, or why you want to reinvent the wheel.
Pumps do not like to "pull" a liquid, they much prefer to "push" it.
The higher the demand, the great degree of difficulty and the higher the expense involved in make a pump that "pulls" work.
Adding the G force of acceleration to that only makes things worse.
There is a good reason 99% of all faster Stock and Super Stock cars run a rear mounted electric fuel pump such as a MagnaFuel or Aeromotive, at or behind the cell.
Old 08-19-2014, 08:01 PM   #3
Lee Valentine
Liked 319 Times in 68 Posts
Why introduce engine heat to the fuel system?
Lee Valentine 1661 STK
Old 08-19-2014, 10:36 PM   #4
Dragsinger
my question comes form years of bracket racing with a BLP belt drive pump and bypass regulator.
That sure works good, low fuel pressure at low speed, full pressure at race RPM.
I thought some might be running an engine mounted pump, looks like not.
Out of curiosity, do we know what NASCAR engines use for fuel pump? I have seen photos of those engines with block mounted pumps.
Larry Woodfin 471W
Old 08-20-2014, 12:43 AM   #5
SST3193
Liked 2 Times in 2 Posts
Looking around the web and found the Nascar boys used these, until fuel injection a couple years ago.
http://www.watermanracing.com/Produc...-w-bracket.jpg
SST3193 is offline   Reply With Quote
Old 08-20-2014, 09:02 AM   #6
Jim Craig
Liked 5 Times in 3 Posts
....and they could still use this style fuel pump for EFI, but someone decided against it.....way too much thinking over there on the easy stuff
Jim Craig is offline   Reply With Quote
