Old 08-10-2014, 10:47 AM   #1
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Coan XLT Turbo 350 Issues
In my wife's Cutlass we have always run a PG trans with no issues. A couple of years ago we purchased a Coan XLT lightweight turbo 350 w/clean neutral used but freshened from Coan with zero runs. We finally had a chance to try it recently and at the top of the wheelstand in low gear it felt like it almost like a rev limiter for a moment. I still ran it thru and went I clicked it into clean neutral and shut the motor off the engine continued to turn over. Pulled the trans to find the direct clutches had welded themselves together. After talking to Coan they wanted to see the valve body and pump and supplied a baffle for the pan to eliminated cavitation during a wheel stand. After $1200 later with all the upgrades the trans was redone with new clutches etc. and clearances provided by Coan. Fast forward to yesterday and we ran it again. Result? A complete repeat of our last runs. Car falls flat on its face at top of wheelstand and the clean neutral doesn't work. I've checked the cable adjustment several times. I haven't pulled the trans apart but I'm assuming the direct clutches are burnt up again. Any trans gurus out there with a solution?
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 08-10-2014, 06:25 PM   #2
Jody Lang
Liked 92 Times in 29 Posts
Default Re: Coan XLT Turbo 350 Issues
I would guess a cross leak between 1st and high gear.
I've seen this with a well known builder on a 350 reverse pattern. Aluminum separator plate and no gaskets. 1st and 3rd we're right next to each other on the plate. Top of 1st it would start applying 3rd and give a running out of fuel feel to it.
Just my guess
Jody Lang is offline   Reply With Quote
Old 08-10-2014, 06:41 PM   #3
James Packer
Liked 3 Times in 2 Posts
When the car is stopped and in neutral, does the car try to move as if it's in gear?
James Packer is offline   Reply With Quote
Old 08-10-2014, 06:54 PM   #4
James Packer
Coan probably wanted to see the valve body and pump to check for crossleaks.
Old 08-10-2014, 08:11 PM   #5
Bob Gullett
In the clean neutral position it does. The regular neutral it doesn't
68 Chevy11 327 F/S
Old 08-10-2014, 11:45 PM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If you get on the Coan website, they have a break down of the tricks in the XLT. It seem to me if you are in the clean neutral position, and the direct clutch is welded, then to get the car to move there must be a cross leak into the forward clutch . Could be leaking at the manual valve, or could be mis alignment of the valve in the clean neutral position.
The XLT 350thm doesn't have an intermediate sprag, so I think it is critical how the second clutch comes off as the direct clutch comes on. If second clutch is slow to come off, or has a restricted exhaust, then this might be the reason the direct clutch burns up, due to a tie up on the 2 to 3 shift. This could be a problem with how the manual valve is positioned in the valve body during the shift.
Old 08-11-2014, 12:22 AM   #7
Charlene Gullett
Charlene Gullett's Avatar
Liked 7 Times in 2 Posts
After the first time this trans smoked the clutches-1 pass down the track (Coan had just freshened this trans) , Coan has since updated the valve body, supplied a new pump and an oil pan with baffles in it for a super stock application( it was not free) . According to them, this is everything I needed. they also supplied every spec on clearances etc. What happened?? We hooked up a pressure gauge and are at a constant 200 psi at all forward gears, reverse, and with the transbrake engaged at 2000 + rpm.
I am having trouble finding that this could happen twice in 2 freshens after one hit on the track (one freshen by Coan and one by a rep trans builder) .
Coan's site talks about wheel standing cars and fluid cavitation. I eliminated this-tied down that front end. Minimal wheel stand action-same problem.
very frustrating!
6521 GT/MA 85 Cutlass
Charlene Gullett is offline   Reply With Quote
