Old 07-27-2014, 08:49 PM   #1
Dale Rethke
Default Starting line lull after start??
I have a problem and I am not sure what this could be doing this but when I leave the start the car leaves then has a little lull you might say then goes again?
I have a video of it after take off you can see the front of the car drop when it does this then pick back up after the lull if we can call it that.
Any Info would be appreciated.
Thxs
Dale Rethke
Dale Rethke is offline   Reply With Quote
Old 07-27-2014, 10:25 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Starting line lull after start??
judging by the black smoke under the car when it happens it may just be a fuel slosh issue. what carb is on it? sometimes all it takes is an extention on vent tubes
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 07-28-2014, 07:01 AM   #3
Bob Bender
Bob Bender's Avatar
Liked 462 Times in 92 Posts
The carb is just too rich ??
Bob Bender 144 O/SA
Old 07-28-2014, 07:57 AM   #4
Ed Wright
Ed Wright's Avatar
Floats too high?
Ed Wright 4156 SS/JA
Old 07-28-2014, 12:00 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: Starting line lull after start??
Accellerator pump duration is too long and is continuing after the main circuit is fully active?
I like the "floats too high" encouraging "slosh out the vents" theory as well.
LOCOMOTION Racing
Old 07-28-2014, 07:41 PM   #6
Dale Rethke
Talking Re: Starting line lull after start??
Thanks for the reply everyone
It has the AVS carb on it as you probably know so I will give this input a try.
You really notice it more when you watch the video then being in the car it seems.
Thxs again all
